Evo X Launch
Old Sep 9, 2011 | 07:06 AM
Horus's Avatar
Originally Posted by chef_tony_t
if you hold in the asc button for 3+ seconds it will completely turn off the traction control and also will enable the 2-step launch control. after its all the way off you hit the gas and the rpm's jump between 5000 - 5500rpm. then the rest is on you
I'm not sure if the 2011 GSR's are different but I don't have to hold the button down for 3+ seconds for the launch control to enable. If I hold it down, it beeps and then a yellow AYC off light comes up on my dash. Is this what you mean?
Old Sep 9, 2011 | 11:27 AM
flyinmonkey101's Avatar
I use launch control on the strip normally with 340hp and stage 2 exedy. Anyone have a comparable setup? My cluctch and/or diff makes a bad sound under heavy load...
Old Sep 9, 2011 | 11:42 AM
guswaym's Avatar
hold the button for 3+ seconds to completely disable traction control
factory launch control is always on and set to like 5500 rpm imo its a clutch destroyer
Old Sep 10, 2011 | 12:05 AM
Horus's Avatar
ok so what is the difference between disabled and completely disabled? meaning what's the difference between hitting the button normal and holding the button for 3 sec? (not being sarcastic at all)
Old Sep 12, 2011 | 05:45 AM
It probably says in the manual. Ive always just shut it off completely so my lap times dont suck.
Raceghost
Nov 16, 2016 08:53 PM
philamthebest
56
Feb 15, 2014 09:43 AM
norlanrodriguez
Dec 16, 2012 08:24 PM
poodlemaster
Driving Techniques
67
Jul 3, 2010 02:04 PM
