26psi stock
Old May 20, 2011 | 08:39 PM
Ltdanish07's Avatar
26psi stock
Well i just installed my boost gauge and it says my peak boost is 25psi, eventually tapering to 16 which is normal. My vac is 20 at idle and 23 24ish while driving.
ideas? im not sure if my sensor is bad or what. Only mod i have is a cat back exhaust. I do have a slight exhaust leak but i dont know if that would be the problem.
Thanks for the help
Old May 22, 2011 | 09:16 AM
Bizzlex's Avatar
sounds about right, obviously when you drive the more gas u give the less vaccume you will get, and does your boost just jump to 25 psi then start dropping to 16?
If you have not gotten it tuned then finish modding it and get her tuned!
Old May 22, 2011 | 11:36 AM
Ltdanish07's Avatar
My peak boost is 25-26 psi. Im just surprised because i thought peak was 21psi dropping down to 16. The boost is eventually dropping to 16, but its usually time to change gears before it does.
No tune yet, soon though. I need to put the rest of my parts on. Im hoping the tune will help smooth everything out.
Old May 22, 2011 | 11:49 AM
Kracka's Avatar
My guess is inaccurate gauge. Log it through the ECU for actual numbers.
Old May 22, 2011 | 11:43 PM
Ltdanish07's Avatar
Thats what i thought but it still tapers down to 16, which would be correct.
Old May 23, 2011 | 10:23 AM
steinvb12's Avatar
I had spikes without a tune that were about 23psi or so. And that was with an exhaust and a drop-in similar to you. So 25psi isn't that outrageous. But wouldn't run 25psi for too long without being tuned.
A tune should straighten you right out.
Old May 25, 2011 | 09:23 AM
Bizzlex's Avatar
yea man, i run 27psi all day but its tuned for that, so finish with your quick bolt on upgrades and get her tuned!
Darknightevo
Dec 16, 2010 07:11 AM
2005evo8gsr
Oct 16, 2010 02:41 PM
RNSpeed
Nov 14, 2009 12:09 PM
ArchieBabes
May 21, 2008 03:01 PM
evotino
Jul 24, 2005 11:07 AM
