fidanza clutch
Old Jul 8, 2011 | 06:55 AM
Bizzlex's Avatar
fidanza clutch
Is the fidanze V2 series single plate clutch a stage 2, will i be able to launch all day like a boss with no issues, and how are their aluminum flywheels??? Thanks!
Old Jul 10, 2011 | 10:17 AM
Bizzlex's Avatar
bump
Old Jul 10, 2011 | 01:23 PM
Logitech80's Avatar
I heard light weight flywheel is not good for lunching the car... Stock flywheel is fine for lunching the car. Not sure about bullet proof clutch
Old Jul 12, 2011 | 08:47 AM
ErnGotti's Avatar
The fidanza is 9lbs, ACT and Clutchmasters make 11 pound ones. I would go with a heavier HD flywheel, because, even though the fidanza is serviceable, the job is an absolute PITA to get to it. Being 2 lbs lighter than the ACT and Clutchmasters, there is a better chance of warping under high heat situations, like launches
Old Jul 12, 2011 | 09:10 AM
Kracka's Avatar
^You're forgetting that aluminum is able to dissipate heat more quickly than steel though.
I'd personally just get the MAP flywheel since it's the same, but cheaper.
Old Jul 14, 2011 | 04:35 AM
Bizzlex's Avatar
So the fidanze aluminum flywheel thats rated at 700 Torque is no good? if i had 600 torque maybe... but i still cant find out if this clutch is stage 2 or not
street2dirt
11
Apr 10, 2013 05:03 PM
evo8kg
Dec 31, 2011 02:28 PM
2weelz4me
10
Jul 6, 2011 01:04 PM
vladdyyy
Evo X How Tos / Installations
Oct 6, 2008 07:28 PM
EvolNinja
Mar 27, 2008 11:20 PM
