Cobb Tuning XLE BOV
If you have the DV in the stock orientation (vacuum hose pointing up), one option is to spray some Triflow down the hose into the DV. Not sure how well it will lube the entire piston though. The other option is to remove the DV turn it over so the side of the piston is visible, put a few drops of lube on it, and then cycle the piston to disperse it.
Crackerjam
Sep 15, 2015 03:12 PM
