Meth Injection Kit Advice?
Old Apr 14, 2012 | 09:18 PM
user 629782012's Avatar
Originally Posted by sparky
Whoever told you that you could only run 20 PSI on 93 octane, and that you would need Meth or race gas to push it farther, just doesn't know what they are talking about.
I am assuming that you can still get 93 octane pump gas in your area. With the right tune, you should be able to run at least 24 PSI on straight 93 pump. That is with the emphasis on the "right tune."
dude he just said he can only get 91..
to the op.. run what ever ya want! but do some research
Old Apr 17, 2012 | 11:03 AM
SilverEvoX's Avatar
Originally Posted by BoostAddict420
Running a walboro 255 and 950cc injectors. What are advantages to e85 over regular with a meth kit and does anything else need to be done to switch other than flip the tune?
Thanks for the replys guys it's been a big help.
950cc on a green will probably be too small to run E-85 IMO. I'd kick it up to 1100's and it should support it. E-85 is 105 octane and is fairly consistent although up north they have a true summer/winter blend where it changes a few points when the season change. I think E-70 is the worst it can be up there and true E-85 being the best readily available with E-98 also available but not at any pumps.
The biggest advantage of E-85 over meth is that there is nothing additional to the stock fuel system setup that can fail. You don't have a meth reservoir that can run dry or reservoir level indicator that can malfunction making you think you still have meth, nozzle failure, wiring failure, etc. A good meth kit runs about the same price as injectors and a walbro also for that matter unless you're talking 2k+ cc injectors.
You just run the tank empty from pump gas or as low as you can get it, i.e. below the 2nd low fuel light some if possible, switch the tune's, and off you go. Other advantage, as long as E-85 is 50cents a gallon cheaper than premium you end up saving money despite the fact that E-85 burns 30% faster than pump gas, assuming a $3.50+/gallon pump gas.
If you browse the boards overall you'll find that anywhere E-85 is available it is almost always the option people choose over Meth because it is simply more reliable and easier overall.
Old Apr 17, 2012 | 01:39 PM
BoostAddict420's Avatar
Thanks SilverEvoX that was extremely helpful. My tuner has a huge preference to meth kit for daily driving. Probably just going to spend the right money and get a high quality kit thats less likely to fail.
Upon failure though whether it be running the tank dry or nozzle fail....what would be the result? Would that blow it up or just cause it to cut out and loose boost?
Old Apr 18, 2012 | 12:05 PM
SilverEvoX's Avatar
Depends on how good the fail safes in your kit are and how close you're watching everything via gauges etc. If you had it tuned to say 12.5:1 AFR with a healthy dose of meth and then the meth quit and your failsafes didn't dial timing/boost/afr back it could blow the motor. Conversly if your failsafes worked as they should it would just detune.
Old Apr 18, 2012 | 12:18 PM
Boltz.'s Avatar
FCOTM Winner
I have a meth kit for sale. Aquamist HFS-6, in perfect working order. Can even throw in a couple tanks and remote filler for you. Had it sitting around for a bit, willing to give a killer deal on it. PM me.
Old Apr 19, 2012 | 10:01 PM
AWDs's Avatar
Don't tell the OP that he is going to need larger fuel injectors if he is going to be running Meth! This is not necessarily true. In fact, the opposite is usually the case. If he were to decide on running E-85, on the other hand, then he would need larger injectors and most likely a higher volume fuel pump.
So you're saying max out your stock injectors, and then just dump in a bunch of meth?
Bacek88
May 24, 2017 05:33 AM
nsheasley
Dec 7, 2015 07:11 AM
JeyEvo
Dec 8, 2014 10:30 AM
KevOVIII
E85 / Ethanol
Dec 18, 2008 11:09 AM
jasonrp15
39
Jan 18, 2007 05:12 PM
