Injectors and Fuel Pump
Old Apr 22, 2012 | 10:18 AM
chriswolf81's Avatar
I run the DW300 pump with FIC1100's. I think they are matched very nicely.
The pump runs very quietly and is supposed to flow much more fuel than the 255's.
And the best part is it fits in the same mounting kit as the 255, so you can switch fast.
Old Apr 22, 2012 | 11:55 AM
waltezee's Avatar
The DW 300 is an option also another option would be the Bosch 044 but keep in mine if you the Bosch you will need to upgrade the FPR.
Old Apr 22, 2012 | 09:55 PM
ceazars_evo's Avatar
is the dw300 a direct bolt on from stock?
Old Apr 23, 2012 | 05:22 PM
It requires the same install kit that the 255 walbro uses.
I think unless you get an inline booster pump, no aftermarket pump will work without install kit.
patricknogaj
Jan 21, 2017 06:04 PM
haxr303
Dec 31, 2015 09:41 AM
RalliMark
17
Aug 7, 2012 08:50 AM
scheides
Evo X Dyno Results
38
Aug 10, 2011 08:31 PM
Fidget253
30
Apr 8, 2010 08:32 PM
