Blown Piston Ring :(
Old May 16, 2012 | 09:12 PM
  #46
AJsGenerX's Avatar
Originally Posted by CBRD
OUCH!
cb
I said the same thing. My heart sank when we pulled the pistons out.
Old May 16, 2012 | 09:24 PM
  #47
4RETECH's Avatar
Originally Posted by AJsGenerX
I dont data log but i sure will now. Im not sure what went on during the dyno session but my maf sensor blew the same day. Im not here to make any accusations or burn any bridges. Whether my tuner saw it or not doesnt matter anymore. Its a risk you take when you sign that waiver before you strap on to the dyno. When all set and done, the car will be visiting Chad at CBRD.
Hey, I'll go down with you to CBRD, we can make it a group trip.......as always, if you need anything text me.
Old May 16, 2012 | 09:30 PM
  #48
AJsGenerX's Avatar
Anyways, today I ordered a bunch of parts which ran me $6000+ for this engine build. The list is finalized and as follows:
1. Wiseco 9:1 pistons
2. Manley Turbo Tuff I beam rods
3. ACL Rod bearings
4. ARP head studs
5. Supertech Intake and Exhaust Valves
6. Supertech dual valve springs and retainers
7. GSC S2 Cams
8. Walbro 255
9. MAP 1000 cc injectors PnP
10. Ported Intake Manifold
11. Fully ported MAP EF3
12. Competition stage 2 clutch
13. ACT Streetlite Flywheel
14. AMS Clutch Master Cylinder Upgrade
Chris at MAP hooked me up. He has excellent customer service skills and provided me with everything I need even after business hours on his own time. A BIG THANKS goes to Chris Carey at MAP.
-AJ
Old May 17, 2012 | 12:31 AM
  #49
baggelis's Avatar
Were your cylinder walls okay or completely scraped?
they re a little scraped but nothing major im going with wiseco pistons manley h beam rods supertech valves springs and retainers and maybe just maybe gsc s1's and an ef2 or ef3 lol and i only say s1's because im never gonna need s2's unless i build my sst to withstand more power
Old May 17, 2012 | 06:20 AM
  #50
AWDTerror's Avatar
Good luck. That's some massive detention to cause cracking like that.
I'm neurotic with my car so I always have my cobb ap hooked up and set to display knock.
Old May 23, 2012 | 08:36 AM
  #51
AJsGenerX's Avatar
Parts drop shipped from vendors are arriving. Here's an update of what I received so far for my build.
AMS Clutch Master Cylinder Upgrade:
Competition Stage 2 Street Series 2100:
I will update this thread as more parts start to roll in and the rebuilding process goes in. Again, MAP is the way to go
Old May 23, 2012 | 09:16 AM
  #52
TheBlade's Avatar
The piston and rod pics play out like a horror movie for Evo owners :-O
Old May 27, 2012 | 06:48 PM
  #53
AJsGenerX's Avatar
As promised, here is an update of what is going on. I received all the parts beside the MAP EF3 and Intake manifold. They had just received my stock turbo and intake manifold for porting on Thursday. I received my ACT Streetlite flywheel, Manley I beams, Wiseco Pistons, ACL Rod Bearings, Walbro 255, MAP 1000cc Plug and Play Injectors, and the OEM Mitsubishi Engine Gasket set. Everything came on Saturday. AMAZING shipping time and customer service by MAP.
Old May 27, 2012 | 09:11 PM
  #54
n2oiroc's Avatar
Alright guys...here's the update of the tear down.
We began tearing down the motor today and was able to successfully remove the head, pistons, and rods in a matter of 5 hours. Cylinder number 4 with the low compression had 2 cracks on the side of the Piston. Piston 1 had 1 small crack on the side as well. Cylinder 1 wall had 2 scrapes. You can feel it gently with your finger nails. I do not want to pull the block so maybe I can get away with honing the cylinder. The pics are as follows:
This thread will turn into my build thread. Hopefully it will be successful
Anyways, we found out what happened. My turbo seals went apparently. All lines, intake, and cylinders were being sprayed with oil. This caused detonation and cracked a few pistons. I don't understand as to how my stock turbo took a dump with only 32k miles on it. There are too many variables. This also explains why my MAF sensor went out on the same day as the tune. Atleast that's what the theory is. Regardless of the past, I look forward to a successful build on a MAP EF3. The head was sent off to the Machine Shop for GSC S2 Cams, Supertech Dual Valve Springs, Titanium Retainers, and Supertech Valves
- AJ
do not just hone the block in the car and drop pistons in! those cylinder walls do not look good at all. if you just slap new pistons in, you will be doing it all over again soon after you have massive oil consumption and poor compression.
Old May 28, 2012 | 01:16 AM
  #55
Panda_stunter's Avatar
Wow, I wish mine isn't the same. Though the symptoms r the same. I gotta check tomorrow. Hopefully it's nothing catastrophic like yours coz I don't have the money for a build.
Old May 29, 2012 | 01:52 PM
  #56
Semih321's Avatar
now after all these mods will he loose to me a 3rd time? muahahaha
BTW good times in wildwood....the toilet ended up cracking and we flooded the guys bathroom downstairs LOL. I will explain in person.....and nice build f***ker
Old May 29, 2012 | 07:54 PM
  #57
mantella's Avatar
2nd this. You will be cursing your self if you do drop ins. can you exchange the pistons and go up a size. I ran drop ins for a couple of months for fun but it cosumed a lot of oil. I also had alot less miles and damage then yours based on the pictures. Get it machined so you do not have to do it again. I only had a weekend to fix mine where i had a spark plug pop so rigged it till nicer weather.
Old May 29, 2012 | 08:08 PM
  #58
prowakeskater's Avatar
so all of your piping had oil in it?
Old May 30, 2012 | 09:42 AM
  #59
baggelis's Avatar
i ll have to keep an eye on my oil after i put mine back together cause i honed mine a tiny bit and dropped the new pistons in
Old May 30, 2012 | 11:10 AM
  #60
AJsGenerX's Avatar
From what the mechanic said, it looks like we will be able to get away with honing out the cylinders. We will be checking piston clearances soon. I can scrape our fingernails across and feel the scrape but it doesnt stop the finger from going. We will hone it out and see how it feels and go from there.
