Need some help with fluid recommendations
Old Dec 21, 2012 | 09:23 AM
EvoXChii's Avatar
This weekend I would like to change the fluid in my transfer case and also change out the the gear oil. I did some research but its a bit confusing with all the different brands and what goes where, so I went on http://www.redlineoil.com and found:
1. 80W140 GL-5 Gear Oil <-- for my transmission
2. MT-85 75W85 GL-4 Gear Oil<-- for my transfer case
All I'm wondering if those are OK to buy and if they are compatible with my vehicle.
2008 Evo GSR 5 speed.
Old Dec 21, 2012 | 11:47 AM
Kracka's Avatar
No, wrong fluids in the wrong places!
transmission: http://www.maperformance.com/redline...l#.UNZUDobedg0
transfer case & rear differential: http://www.maperformance.com/mitsubi...l#.UNS8zIbedDs
rear differential: http://www.maperformance.com/mitsubi...l#.UNS84YbedDs
Old Dec 21, 2012 | 06:41 PM
Buru_EvoX's Avatar
Hey Kracka, the link you posted for "transmission" came up as the ams performance gate selector bushing. Did you mean a fluid? I'm looking to do my 15k maintenance as well so I want to know which fluids I need. I have a GSR.
transmission: http://www.maperformance.com/ams-per...l#.UNSUCIbedDs
Old Dec 22, 2012 | 09:39 AM
EvoXChii's Avatar
I think I undertand:
Tranny:
Mitsubishi Diamond ATF SP III & AMS Performance 5 Speed Gate Selector Bushing Kit
Transfer Case:
Mitsubishi DiaQueen GL5 LSD Gear Oil
Old Dec 22, 2012 | 04:34 PM
Kracka's Avatar
Nope, I'll go fix my links when I get a chance.
Old Dec 22, 2012 | 04:45 PM
Kracka's Avatar
Transmission link fixed.
Old Dec 22, 2012 | 09:56 PM
Buru_EvoX's Avatar
Thanks Kracka! I have my 15k maintenance that I need to do. I'm wondering if I need to replace all my fluids for it, or if I can just get away with cleaning my intake filter and changing my oil. I figured I would just get all of the fluids just in case. I haven't tracked my car or beat on it.
Old Dec 23, 2012 | 05:59 AM
Kracka's Avatar
All the fluids too.
Old Dec 23, 2012 | 08:34 AM
Iowa999's Avatar
In case you are wondering why Kracka suggested two different fluids for the rear diff, it's because there are two different sections to the rear diff and they require different fluids. The attached picture, hopefully, will make it clear:
Attached Thumbnails Need some help with fluid recommendations-sawcevoxfluidguide.jpg
Old Dec 23, 2012 | 08:38 AM
Iowa999's Avatar
The other question that comes up is whether you need to change the fluid in the ACD/AYC pumping system. The answer is No. You keep some Mitsubishi Diamond ATF SP III around for topping off the reservoir in the trunk, but you don't need to change it and you really don't want to because the bleeding process for this system is a pain in the tuchus. Wait until your transfer case blows up and change and bleed then.
Referring to the picture attached to the previous post, you swap the yellow and red fluids every, say, 15,000 miles, but you don't touch the orange fluid unless you have to. At most, you siphon some ATF from the reservoir and refill with new, but you don't swap the ATF fluid used by the pump unless you have to.
Old Dec 26, 2012 | 08:18 AM
EvoXChii's Avatar
Sweet, I ordered my fluids minus the Mitsubishi Diamond ATF SP III, since I don't need to change it, I'm not to worried about it.
Thanks for the help guys.
Jack_of_Trades
May 29, 2018 07:05 AM
Gruppe-S
EvoX 'For Sale' Electronics / Lighting / Audio
Apr 20, 2017 08:06 PM
CatalystGod
Evo X How Tos / Installations
20
Dec 12, 2016 01:36 AM
dokeun85
Mitsubishi TC-SST Discussion
Aug 30, 2015 03:16 PM
zmeli
11
Sep 7, 2004 03:22 PM
