Light smoke in boost.
Old Mar 2, 2013 | 01:10 PM
RoLLy's Avatar
Mine will throw some smoke out of the exhaust when I go WOT, did it when I bought it stock, and does it now with all my mods. Did it in my last turbo car as well
Old Mar 2, 2013 | 04:03 PM
Jason S-9's Avatar
A smoking Evo X is more common then a non smoking X. Mine smokes with a good tune and a HFC. I'm going to try a new PVC though.
Old Mar 2, 2013 | 04:21 PM
humpevo311's Avatar
If your a/f is in the 11.5- or richer range at wide open throttle it's likely to smoke, the smoke usually thins out with rpm a bit. That amount usually increases the more fuel there is, the blue trails after wide open throttle runs are usually more attributed to pcv. If you can ride behind the car have someone drive by on the throttle you should be able to tell my smell what the smoke is generated from oil or fuel. Also keep an eye on oil levels, and yes it's pretty normal for an x to consume a little oil. Also keep an eye on it at startup, if it's the turbo (which I highly doubt) it will often smoke a little on statup.
Old Mar 2, 2013 | 07:31 PM
HAHAV8's Avatar
My X burns no oil right now.
Yes the smoke comes as a large puff after going WOT then dissipates as you get higher in the revs. Even at 11.5-11.7 my car still blows plenty of smoke.
Strictly burnt fuel though
Old Mar 2, 2013 | 07:36 PM
migs647's Avatar
Every X I've seen smokes. I didn't think mine did either, till I let my wife drive it and she was getting gnarly with it and I was behind her. Definitely smokes @ WOT. Turbo back
Old Mar 3, 2013 | 05:13 PM
vegittoss15's Avatar
Actually I was mistaken. Mine made light smoke when I had no mods. No smoke on built motor lol.
Old Mar 14, 2013 | 03:16 PM
NeedBoost!'s Avatar
Originally Posted by vegittoss15
I've had a turbo back for about a year now and I have a built motor. Still no smoke.
Ask a friend to trail close behind you when you take off from a stop light - guarantee he/she will disagree with you.
Old Mar 15, 2013 | 07:02 AM
Actually speaking of which, my friend did say I have some smoke.
CGroovy2k2
Dec 3, 2015 05:54 PM
eldiablo79
Oct 18, 2009 11:03 AM
EVIL_EVO_VIII
May 26, 2006 03:56 PM
IXmr321
Feb 23, 2006 01:41 PM
schepis
Lancer Aftermarket Forced Induction Tech
21
Oct 14, 2005 02:02 PM
