Another Bad AWC PUMP :(
Well chalk up another bad awc pump. A month ago it got warm outside and I got the dreaded awc service required icon. Came on some days, other days it wouldn't. Weather got cold again and the light did not come on for over a month. Had another warm day today and light came on again. Seems if the temp is under 50 degrees the light does not come on. If its warmer then that it comes on, I am guessing the heat expands the pump?? After doing some research I am positive its the awc pump. I have an 08 with 40K miles, so I'm sure the dealer will tell me to bend over! $2 grand to replace it??? WTF!!! You think
is going to do anything about this? Seems like a huge problem with a ton of Evo's.
I can tell you from experience it will NOT be warrantied under the 5yr/60k mile warranty. OP please read the following 2 threads, and then go and submit a complaint.
https://www.evolutionm.net/forums/ev...-failures.html
https://www.evolutionm.net/forums/ev...wc-system.html
I can tell you from experience that they didnt warranty mine at 37k cause i was 1k passed the bumper to bumper warranty
F the Mitsu reps!!!!!!!!!
Did you have some sort of extended warranty? Also, WHEN did you have yours replaced. Mitsubishi may have changed the warranty due to so many going out.
There are some peeps who drive their Evo/RalliArt's with bad pumps for well over a year/thousands of miles.
xop32
Jul 17, 2012 03:15 PM
mshilto89 thanks for the links, complain filed. What else can be done?
