Fueling for BBX Full on E85?
Old May 20, 2013 | 11:12 AM
Inprogress's Avatar
I'm looking at going E85 on my X with a BBX full that I currently have.
What would I need as far as fueling is concerned?
I currently have ID1000cc injectors and a Cobb Walbro 255lph fuel pump kit.
I was told a set of FIC 1100cc injectors and a Map FPR kit should be good and I've also been told that wouldn't be enough, will I need more fuel than this?
Any suggestions?
Old May 21, 2013 | 05:15 AM
evokid4life's Avatar
id do a bigger pump like a wally 400 (E85 version) and the FPR kit and you should be good cause you can bump your base pressure to flow the ID1000s a bit more
Old May 21, 2013 | 07:38 AM
Inprogress's Avatar
But can the E85 version of the walbro 400 also take 93 octane fuel? I'll be on pump 93 80% of the time
Old May 24, 2013 | 12:07 PM
r34p3rex's Avatar
Yes. Pumps are only given a E85 rating if the seals inside can ALSO withstand E85 in addition to regular pump gas
Old Jun 26, 2013 | 12:16 PM
Inprogress's Avatar
Couldn't running a FPR Kit alone, in addition to my ID1000 and Walbro 255lph, get me the flow i need do E85 on my BBX turbo?
Old Jun 26, 2013 | 12:35 PM
desiromeo812's Avatar
My ID1000 and Wally 255 maxed out at like 430WHP VD setting, 27psi on EF2.. had to taper boost past 5500 to be able to have safe AFR's
Old Jul 7, 2013 | 02:33 PM
1EvilPBx's Avatar
you can do the new id1300 injectors and call it a day
ddlopresti
Aug 27, 2016 01:05 PM
ddlopresti
Evo X Dyno Results
43
Apr 28, 2016 07:37 PM
haxr303
Dec 31, 2015 09:41 AM
ceazars_evo
18
Apr 23, 2012 05:22 PM
CBRD
Evo X Dyno Results
21
Sep 4, 2011 10:54 AM
