Clamp/detach problem Spec Stage 1
Old Aug 20, 2013 | 08:44 PM
Lenzi's Avatar
Hi, I'm from brazil so sorry for the bad english...
I've just installed a spec stage 1 clutch on my Evo X GSR, but it do not work. Stock flywheel and CMC.
I do not know exactly how are the words in English, but I'll try to explain the situation.
My mechanic said that by stepping on the clutch pedal it does "not take off/detach" enough to engage the gears.
Where can be the problem? Clutch defect? Need CMC upgrade? Throw out bearing?
If you guys could help I'd appreciate a lot!
Thanks
Old Aug 24, 2013 | 06:24 PM
IRPerformance's Avatar
Either the clutch isn't adjusted right, wasn't bled right, or you have another problem like a bad master/slave cylinder.
cocobobo20
Jan 29, 2015 06:12 PM
awdfun
Jun 7, 2014 11:04 AM
wiser1000
Feb 19, 2014 06:34 PM
Alkaedas_Inc
Jul 8, 2013 11:12 AM
Psychedelic
Oct 26, 2011 11:39 AM
