competition stage 3 or spec stage3+?
Old Apr 10, 2014 | 05:39 PM
awdfun's Avatar
Well, my clutch decided it was time to crap out. It's slipping in 3rd, 4th, and 5th. It jumps up about 300-400 rpm's before it catches. I've been doing a lot of research and I was leaning towards the spec stage 3+ but I also found good reviews on the competition clutch stage 3. Either clutch will suit my needs and I want a full face pressure plate. That's why I've narrowed it down to these two. I'm fully bolted running cobb stage 2+sf tune. I switched to cobb stage 2 a month ago when I finished my exhaust mods and that's when my clutch started slipping. Future plans are mhi 18K, dw65c, 1000cc injectors, and kelford 214b's. Shooting for 400/370 or so. So I'm not going too crazy, I know either clutch will handle it fine. I was leaning towards spec stage 3+ because people said it was fine on stock cmc. I just had the cmc recall done like a month ago, so I have the stronger revised cmc. Don't want to upgrade it at this point. Is the competition clutch stage 3 as easy on the cmc as the spec stage 3+? Or do you really need the magnus or ams kit to run the comp clutch? If I need to upgrade cmc to run comp clutch I guess it's spec 3+ for me. Anyone with either one of these clutches, please chime in...
thanks
Old Apr 10, 2014 | 05:59 PM
sfcmotorsports's Avatar
I have the comp stage 3 with the comp steel flywheel and I like the setup. The pedal is really not much heavier than stock. I do have the ams upgraded Cmc. I doesn't really matter what type of upgraded clutch you do you Need to upgrade the Cmc the stock plastic Cmc can't handle the the extra pressure it will break and leave u stranded . Most performance shop will no put an upgraded clutch without the Cmc upgrade also . Good luck with your upgrade with whatever u choose!
Old Apr 10, 2014 | 07:46 PM
IRPerformance's Avatar
I prefer Competition Clutch or ACT. I've never had good results with anything from Spec. They are grabby and wear out fast.
Old Apr 12, 2014 | 11:54 AM
pudge23869's Avatar
I have the comp Stg 3, about 8k on it now and I love it. I am still running it on stock CMC but will have the recall done soon. All in all it's a great DD clutch that you know can handle bigger power. I kept the stock flywheel in place and haven't had any issues. I haven't launched the car yet but drive it aggressively and it makes for crisp clean shifts. It gets my reccomendation!
Old Apr 12, 2014 | 05:31 PM
awdfun's Avatar
awesome! it's good to hear that someone is running this clutch on stock cmc without an issue! I have the recall done so I think my car should be fine with this clutch.
Old Apr 14, 2014 | 11:10 AM
Eric30's Avatar
This just answered a question I came on to find out. I was going to post asking about the comp and the spec as well. I think I am going with the comp stage 3 on my stock cmc, once my new clutch is in I will get the recall done. I am going to put in a new flywheel also. Hope to have it done by next week, I am going to order today!
E
Old Apr 16, 2014 | 01:29 PM
Pudge23's Avatar
I should also mention that I had the PILL removed at the same time I did the clutch. It greatly improved the feel of the clutch and engagement of the clutch. I would DEFINITELY do the pill when you do the clutch or CMC.
Old Apr 16, 2014 | 04:05 PM
awdfun's Avatar
cool, thanks for the info. I'll definitely be getting the pill out of there when I have the clutch done.
Old Apr 17, 2014 | 08:59 AM
The problem with removing the pill and upgrading the clutch is it lets you dump the clutch, which in turn will break something else. I have a customer in the shop right now that is on his third rear differential because he likes to launch the car. Just something to keep in mind.
Old Jun 7, 2014 | 11:04 AM
Pudge23's Avatar
Your customer needs to learn how to slip his clutch a bit, just dumping your clutch while the engine bounces off of the launch control is just plain stupid, customer needs a lesson on physics!!! Should also learn some self control and try not to launch his car so much, save it for the track!
Lytec
21
Aug 1, 2019 02:03 PM
cocobobo20
May 9, 2016 12:09 PM
Darksun280
Apr 20, 2013 01:19 PM
raytrix
Dec 2, 2012 08:00 PM
m0nkie
Oct 19, 2012 10:04 AM
