Sponsored by:
Sponsored by: CARiD
Clutch pedal not fully bouncing back up
Old Oct 18, 2012 | 06:22 PM
m0nkie's Avatar
Clutch problem again..
2008 Evo X GSR here. I have Exedy Stage 1 clutch and ACT flywheel.. my CMC went out the window a year ago (Oct. 2011), trapping me in the middle of the freeway.
I replaced the CMC with SSP CMC V3. Everything worked perfect.
A few weeks ago, my clutch wouldn't return back up after fully engaging. It's not broken. Just stuck on the bottom. My car feels like it's about to stall. I can just use my toe and pull it up back. This happened about 7-8 times within the month. It feels like it's getting stuck at the engaging point. Sometimes when I move from dead stop, the pedal would feel like it's stuck there, then bounce back. Sometimes it's just stuck there. Most times it works fine... This is slowly getting worse...
Anyone know what could be wrong? I have to take it to a shop.. anything related to CMC fix is going to cost a few hundred I assume
thanks for any help
Old Oct 18, 2012 | 06:26 PM
JReid's Avatar
Contact SSP about it. Could be the seals or rings going bad in the CMC?
Old Oct 19, 2012 | 07:03 AM
►EvolutionX◄'s Avatar
I think there was a huge thread about this... something like the internals of the CMC failing. As He^ said, I would contact SSP and see if they will help you. Otherwise, I know AMS came out with a solution as well.
Old Oct 19, 2012 | 08:01 AM
m0nkie's Avatar
I remember an issue thread with SSP... but thought that was only their V1 and V2..
thanks, ill see if SSP can help
Old Oct 19, 2012 | 10:04 AM
hawaiianstyle's Avatar
It's a faulty part. I had a thread on this. My car did the same thing with an aftermarket CMC. Send it back to the manufacturer and thy should replace if its a known issue.
Rasperin
Jun 6, 2017 08:32 AM
EastonGSR
Apr 25, 2017 08:59 AM
The_Police
Apr 6, 2016 07:05 PM
Chris725
Nov 24, 2015 06:40 AM
Hotsauce101
Apr 27, 2015 09:40 PM
