What else to support a MHI 18k?
Old May 12, 2014 | 11:42 AM
formerSTIowner's Avatar
I have one going in early June. At that point I will have:
Fuel injectors (1100) and pump
ETS 4" IC and L/UICP
GS 3 port
MHI 18k, ported
ETS CAI
ETS TBE - V2 quiet
Synapse BOV
Right now I'm at 320whp @ 26psi on a mustang dyno. Another member with this turbo hit ~370whp on the same dyno. I'd like to see if I can hit the 400whp mark - without pushing the turbo to near death. At first I considered E85 as the easy option to get there, but with the midwest variations in mix I think I will be staying away.
What are some other options and approximate gains?
Ported stock exhaust mani
Ported stock intake mani
Cams
Other?
Thanks!
Old May 13, 2014 | 07:19 AM
No love?
Old May 14, 2014 | 01:29 PM
Do I smell funny? No love?
Old May 14, 2014 | 01:34 PM
ETS Michael's Avatar
Stock replacement tubular manifold and a set of cams will help get you to your goal.
Old May 25, 2014 | 12:02 PM
Mistermarc's Avatar
ETS Michael, is cams really worth it on this turbo, I'm in the same situation and have almost the same exact parts as OP. I'm not sure if its worth the cost to do cams.
Old May 27, 2014 | 01:42 PM
Mistermarc's Avatar
No response?
Old May 27, 2014 | 05:07 PM
I called AMS and Boostin and they both recommended against it given the cost vs gains. Considering cams are $500+ and I've heard 6 - 10 hours for install plus springs and install you are likely pushing $1500+ for 15-30 hp... Based on that I've decided against it.
Old Jun 26, 2014 | 08:08 PM
Got PSI's Avatar
do you think you're starving for fuel? how about some more fuel upgrades?
what tune?
also, dump or recirc DP ?
sik_z33
Apr 11, 2016 06:21 PM
sik_z33
Mar 13, 2016 08:33 PM
lbcevo
11
Sep 14, 2015 10:44 PM
formerSTIowner
Evo X Dyno Results
15
Jul 6, 2014 06:14 PM
f-dub
Evo X Dyno Results
17
Jun 4, 2014 04:35 PM
