Building up to a bigger turbo
Old Aug 29, 2014 | 12:42 AM
Kidkuda35's Avatar
So I got a quite a bit of money that I want to put into my 2014 evo x. My goal is to be around 400-450whp before I'm done working on my evo. I know this is a noob question but I was just wondering what kind of modifications I should do to my stock engine before I try to put a bigger turbo in there. The last thing I want is to blow up my engine. I'm thinking I should upgrade my cams, pistons, new intercooler w/ piping, full exhaust system, intake, fuel pump, fuel injectors, and oil lines. What am I missing here? I'm thinking about putting in a gt3582r turbo. Thanks in advance.
Old Sep 4, 2014 | 03:53 PM
ETS Michael's Avatar
I would recommend the following parts.
3.5" or 4.0" Intercooler Kit depending on the turbocharger setup.
http://www.extremeturbosystems.com/E...ooler-Kit.html
Test pipe
http://www.extremeturbosystems.com/E...Test-Pipe.html
One of our 4 cat backs depending your preference.
http://www.extremeturbosystems.com/E...st-System.html
If you plan on going with a 35R setup. We have a full setup with downpipe, manifold, wastegates, etc. If you plan on going with a bolt on turbocharger, which I don't recommend. We can also supply you with a downpipe.
http://www.extremeturbosystems.com/E...Turbo-Kit.html
Depending on your fuel.. you will need some injectors. I really like the ID2000.
http://www.extremeturbosystems.com/I...2008-2012.html
we can also source you a double pump for the fuel pump if you plan on going E85 or if pump gas.. we can get you a single drop in fuel pump.
Tuning I would recommend the Cobb AP
http://www.extremeturbosystems.com/C...olution-X.html
If you have any other questions feel free to send me a PM.
Thanks!
Michael
Old Sep 4, 2014 | 05:34 PM
DSG Performance's Avatar
Bolt-ons and a good tune are really key but take it from advice, too much spool or low end torque can easily destroy this engine. In my experience, going to a bigger, slower spooling turbo is actually safer and keeping the boost down.
The last build on my personal car was a MEGA quick-spooling setup purely made for the fastest 0-120mph possible and required a fully build engine/head.
If you need any advice, shoot me an email: jason@dsgperformance.com
/\ we work very closely with ETS too and they make great bolt-ons/turbo kits, definitely a good path to take
Cheers!
Jason
Old Sep 10, 2014 | 07:35 PM
IRPerformance's Avatar
Basic bolt ons from any of the reputable vendors on here: Intake, intercooler, exhaust, cams, etc.
A 3582 will be pretty laggy on a stock displacement motor. I ran one for a while and was getting 26 psi by 4800-4900 rpm. With a stock motor you will be limited to around 350 wheel torque or you risk throwing a rod, so you won't be able to use anywhere near the full potential of that turbo. Biggest I'd go is a 3576 but a 3071 will make that power and spool ultra quick. If you want a direct bolt on go with ATP. However they are more restrictive with the ATP housing than a comparable turbo and kit from one of the vendors like ETS.
For the Fuel system you will need a drop in pump in the 255-265 lph range on pump gas. E85 will take more pump like Michael said. ID injectors are the best in the business. Although pricey, they are well worth it. ID2000s will have plenty of fuel for an E85 setup. You can go smaller if you don't plan to go that route.
Ihor @ IRP
Mustard Tiger
Feb 27, 2016 03:09 PM
BluEvo88
20
Oct 13, 2014 06:42 AM
Alpha X
Oct 24, 2011 02:26 AM
Qatari MR owner
May 9, 2011 02:26 PM
xceler8rob
Northwest Region
Aug 10, 2009 09:35 PM
