Big nightmare
Old Mar 10, 2015 | 04:21 AM
  #61
Lil Evolution X's Avatar
Originally Posted by turboman86
yea I appreciate all ur opinions.... I think what im gona do is just get a built short block and have the shop put it in and call it a day... I thought about it and if I take all the mods off.... I HAVE to make sure all bolts are tight and look like they were never touched.... then have it towed to dealer, wait a yr and a day for them to examine it... then determine... then do another break in period with the stock block.... pay the performance shop to put the forged stuff in and tune it.. so it just seems cost effective to get the built shortblock and move on.... I just want my car back...
If you have the funds, now would be the best time to rebuild the engine. However, despite the fact that you have modified your Evo, it has only 6,000 miles and is less than a year old. It could have been a factory defect that caused the issue, who knows? You do whatever you feel is right and whatever is in your budget. Note: If you do take it to the dealer, make sure that it WILL in fact be covered under warranty BEFORE you sign off on the repair/replacement, or you will be stuck with the bill after they "discover neglect/abuse/modifications." Because I know dealers have went ahead and repaired the vehicle and then declared fault to customer afterwards. Best of luck!
Old Mar 10, 2015 | 04:54 AM
  #62
turboman86's Avatar
Thanks man.... well I have the funds its the matter of fact what they find and how bad the wife is going to kill me.... I just want my car back
Old Mar 10, 2015 | 06:05 AM
  #63
Spazpilot's Avatar
Turboman86
Whatever shop you use for the new block please make sure you follow these steps that AMS has so you don't get shavings in the new block. If you want a awsome short block i would go with theres. I'm running their 2.4L with my MHI!
http://www.amsperformance.com/attach...%20failure.pdf
Old Mar 10, 2015 | 06:21 AM
  #64
Thumbs up
Originally Posted by Spazpilot
Turboman86
+1
I'm getting my MHI installed soon, how is yours doing with 2.4L?
Old Mar 10, 2015 | 06:31 AM
  #65
turboman86's Avatar
Thanks spaz... hope the damn shops knows to do that..... maybe ill email it to them so they know... what do u think...
Old Mar 10, 2015 | 06:35 AM
  #66
Spazpilot's Avatar
Originally Posted by Evosmokedyou
+1
Spool is super quick but runs out of steam after 6500. I have it tune to 27psi and it tapers to 22psi by 8000. 93 octane
Old Mar 10, 2015 | 06:41 AM
  #67
Spazpilot's Avatar
I would. It never hurts. I do my own work but I'm sure if you take it to a shop that works on Evo's they would know what to do. Then again, now days it's pretty hard to find a reputable shop.
Old Mar 10, 2015 | 07:06 AM
  #68
Ev0ikon's Avatar
Originally Posted by Iowa999
An AccessPort intercepts signals, alters them, and then passes them to the ECU? Since when?
It is exactly what I thought an AP is all these years. Sorry, I stand corrected.
Old Mar 10, 2015 | 08:01 AM
  #69
hoobastnk90's Avatar
So did the dealer get back to you yet?
Old Mar 10, 2015 | 09:46 AM
  #70
turboman86's Avatar
no.. I didn't even bother with the dealer... today is when I find out how much damage was done... and then go from there...
Old Mar 10, 2015 | 02:16 PM
  #71
turboman86's Avatar
Update
so update.... They said complete bottom end is toast nothing salvageable.. theyre looking into it more... FML
Old Mar 10, 2015 | 02:59 PM
  #72
not gonna like i kinda expected that when you said earlier you had to pick up pieces out of the engine bay.. sorry to hear..well maybe you can throw her up on jacks for a bit and start putting some parts together with a builder..
Old Mar 11, 2015 | 11:42 AM
  #73
turboman86's Avatar
Update
so.... found out what it is.... REPLACE THE DENSO SPARK PLUGS THAT COME FACTORY.... the casing came apart, wasn't sparking correctly, cylinder filled up with fuel and all the pressure made it go boom.... its known supposedly and still no f***in recall.. come on.
Old Mar 11, 2015 | 03:52 PM
  #74
meckert's Avatar
Turboman,
Was this the explanation from the shop?
I ask because if the plug was sparking, it was igniting the mixture, if it wasn't sparking and the cylinder was filling as you stated--then you would have had a dead miss--firing on 3 cylinders--something you couldn't help but notice and it would take quite a bit of time to fill the cylinder from the injector--again something that you couldn't help but notice. ( mixture would be pushed out the exhaust as well, never really "filling" the cylinder) A cracked or missing casing on the plug is most notably caused by detonation--ie back to the mixture/tune.
Hate to see you getting what appears to be "odd" diagnosis. Good Luck.
Old Mar 11, 2015 | 03:56 PM
  #75
turboman86's Avatar
thanks man... that's what everyone keeps saying that its returning back to the tune setup... at this point I just want it fixed properly...am I pissed f*** yea I am.. but what am I gona do... roll around and cry... just make it worse..... so its gona come back bigger better and badass
