Sst will only watch gear sometimes
Old Mar 10, 2015 | 06:59 AM
hotsos's Avatar
Sst will only catch gear sometimes
My MR seems to drive normal sometimes and others won't catch gear but will just rev up and not move. And sometimes the reverse R will just blink Any ideas? I'm stumped. I have the sst clutch pack upgraded. Also seems to only happen in cold weather. 60 degrees and above it works fine
Old Mar 10, 2015 | 07:16 AM
Ev0ikon's Avatar
Clutch material going thin?
Old Mar 10, 2015 | 01:28 PM
hotsos's Avatar
I have barely had them for a few months and I havnt tracked or driven it hard. So no clue. And it only happens when it's cold 60 degrees and above seems to work fine.
Old Mar 10, 2015 | 02:01 PM
alsong2002's Avatar
who did the clutch install? what miles on the tranny?
Old Mar 10, 2015 | 02:49 PM
hotsos's Avatar
My shop (Jms racing) drove the tranny up to kozmic to install the clutches. I got about 8k on the new clutches. Cleaned the ssp reusable tranny filter and put new fluid in also
Old Mar 10, 2015 | 03:23 PM
alsong2002's Avatar
if Kozmic did the installation of the clutches than you will be fine. however, if the tranny is old and u just upgrade the clutch without refreshing the entire tranny that might be the problem.
did you or your shop did the teach-in after clutch installed?
the blinking R gears is usually a signal of blown or malfunction of the tranny.
Old Mar 10, 2015 | 04:23 PM
hotsos's Avatar
Yes I did a teach in And also it works sometimes and other times it just blinks . I only upgraded the clutches and not the forks Is it still blown If it works sometimes and not all the time? What else is there to upgrade ?
Old Mar 10, 2015 | 04:53 PM
alsong2002's Avatar
the best things is to refresh the entire tranny when you can. i used to have the blink on my 09 ralliart, i did ended up the sold it at about 60k.
you can call kozmic to see what they suggest you to do.
Old Mar 11, 2015 | 02:56 PM
jayyyw's Avatar
Best bet is to call Kozmic and see if they have any ideas. Did JMS tune the SST tables after the clutch install?
sgambino92
May 27, 2018 07:30 PM
JohnnyBoy427
Lancer Tranny/Drivetrain Tech
Jul 13, 2007 05:38 AM
