Fuel Cut or something else in 5th Gear WOT
Old Jun 23, 2015 | 12:29 PM
normega's Avatar
I was at an HPDE event yesterday and experienced hesitation/chugging/back firing or whatever it was near the end of the day when my fuel tank was less than a 1/4 full on the straight once I shifted to 5th gear WOT.
I've searched around the forums and I can't seem to get a straight answer whether its fuel cut or overboost? (due to OTS Cobb Stage 1 map?)
Currently flashed to OTS Cobb Stage 1, catback exhaust and high flow drop-in air filter.
Advice and comments appreciated.
Thanks
Old Jun 23, 2015 | 01:48 PM
hoobastnk90's Avatar
Did you get any Service engine soon lights? Also it could be your fuel pump relay dying. Also do you mean you only had 1/4 tank left or 1/4 from the tank being full?
Old Jun 23, 2015 | 02:03 PM
rongdoer's Avatar
Does the air filter get oiled or is it paper?
Old Jun 24, 2015 | 01:33 PM
normega's Avatar
No CEL came up and the gas tank had 1/4 or less. Air filter is non-oiled.
Old Jun 24, 2015 | 02:06 PM
Prolly just low on fuel the evo is notorious for that try to always keep it above half! Its more noticiable especially on longer left hand turns.
Old Jun 24, 2015 | 09:58 PM
denlin68's Avatar
whenever i go HPDE I get fuel cut a few sessions in. for me its the tune that its causing my issue. Got it retuned and new tuner said its because track conditions cause the car to overboost and more chance of knock so ur tune will cut power. so u can try running a lower boost map at the track.
Old Jun 26, 2015 | 12:34 PM
normega's Avatar
hoobastnk90 - Exactly that, my fuel cut happened after a long left corner that led to the straight. I can almost hear the fuel sloshing around behind me, or is it?
Would an upgrade to a better fuel pump, or fuel rail make any difference?
Old Jun 26, 2015 | 02:41 PM
No those wont help, you would need a surge tank and there kind of pricey. Its easier to just make sure you keep more fuel in the car! But if you must i think MAP makes one here is the link http://www.maperformance.com/map-sur...shi-evo-x.html
Old Jul 7, 2015 | 09:35 AM
Evodetailer123's Avatar
I had the same problem. It's the relay. Change it. My car is a 2014 and it already went bad.
Thugline
17
Apr 26, 2010 04:42 AM
AWDPowah
Mar 28, 2010 06:56 PM
Poondoggs
Nov 15, 2009 01:46 PM
evovin
Apr 21, 2007 10:08 PM
RalliArtEvoVIII
13
Feb 22, 2005 08:15 PM
