Evo x Running awful Help!
Old Jun 25, 2015 | 04:45 PM
redevo6262's Avatar
Hi, I have a 2010 evo x. The car has a rough idle, and idles from 1k to 2k rpms non stop. The car also will not let me rev out past 3k rpms. Is this some kind of limp mode? Has anyone ever come across this problem? The asc and service required light comes on. The car will not stop doing this. Any help is always appreciated. Thanks
Old Jun 25, 2015 | 10:39 PM
Lightsaber's Avatar
How long have you had the car?
What mods do you have?
What tune do you have?
Old Jun 25, 2015 | 11:16 PM
caduprado's Avatar
It seem it entered some safety mode... My friends lancer does exactly the same: won't let he rev above 3k rpm (or was it 4k? don't remember) and it idles sometimes up to 2k rpm.
In his case, it is some lack of proper tuning after he turboed it with a ralliart setup.
Like Lightsaber asked, what are your mods? Which were the latests?
Old Jun 26, 2015 | 06:42 AM
redevo6262's Avatar
Car just has a full exhaust, intake, and blow off valve. Pro tuned. I just replaced my throttle body since my old one was broken. Does this new throttle body have to be reprogrammed to the throttle pedal?
Old Jun 26, 2015 | 12:30 PM
Bocheggy's Avatar
I had a similar problem with my R32 Skyline back in the day.
I found that it was the MAF.
Old Jun 26, 2015 | 02:42 PM
hoobastnk90's Avatar
Maybe your maf sensor is all crazy since you replaced that. Or you have a massive vacuum leak. I would run some data logs to your tuner and see what he says!
Old Jun 26, 2015 | 10:27 PM
Lightsaber's Avatar
Those are very prudent mods you have here. Like people said, check the MAF sensor. If no avail, take it to a shop for further diagnosis? Overall this shouldn't be any fatal issue.
Old Jun 27, 2015 | 07:27 AM
Thomar's Avatar
Surely there must be a check engine light.
Old Jun 29, 2015 | 01:16 PM
obake214's Avatar
I would say relearn the throttle body first. then can check MAF second. throttle bodies can get sensitive
Old Jun 29, 2015 | 06:55 PM
vishwar1's Avatar
PCMs (atleast GM's PCMs) usually calibrate themselves at some "intervals", between fully open and full closed and then re calibrate its closed loop throttle control. IF you replaced the throttle body, try re learning the throttle. Also if it is in limp mode, they SHOULD be a code thrown by the ECU. Rough idle MIGHT be because of a dirty MAF. Try cleaning the MAF as well.
Old Jun 30, 2015 | 07:39 AM
redevo6262's Avatar
Problem solved! It was a bad throttle body. Thanks for the help!
scott71785
May 21, 2008 11:48 AM
Steiner
Apr 22, 2007 12:41 AM
jjm4life
Aug 6, 2005 07:17 PM
idriveawhiteevo
37
Jun 13, 2004 07:16 AM
alexis525
Feb 24, 2004 01:27 PM
