GT3071R on stock Evo
Old Dec 29, 2015 | 09:11 PM
JrEvoXnitez's Avatar
Yea, 400whp is MHI 18k territory, easily. And its a direct bolt in with OEM mitsu quality..
Went with GT3071R for more power in the long run
Old Dec 30, 2015 | 07:30 AM
LetsGetThisDone's Avatar
I hope your getting a GTX with the 11 blade compressor, and not a standard GT series turbo...
Old Dec 30, 2015 | 07:44 AM
nemsin's Avatar
Is it the stock frame offering GT3071r from ATP? You should also consider the GTX3071r (a little more expensive, but newer design).
I thought 400whp was the goal because you did not want to build the engine. The 3071r is going to spool slower than a MHI TF06-18K. You should look over some dyno charts for the 3071r, they might make you change your mind.
Old Dec 30, 2015 | 07:48 AM
Hopefully its the one Garret makes. They have a GTX3071r that bolts in just like an MHI 18k, so there is no sharp U-turn in the turbine housing like the ATP bolt in stuff. Or he is going with a t3 setup, who knows. Maybe he is just welding a gt3071 to the stock manifold...
Old Dec 30, 2015 | 07:54 AM
nemsin's Avatar
If I were OP, I would get this with a EFR 7670 super core (or 7163 if that is an option)
http://www.evoxforums.com/forums/sho...d.php?t=321914
http://www.boostresource.com/product...hi-evo-x-2008/
I wish someone would make an investment cast hotside for the 4-9 to work with the EFR turbos.
Old Dec 30, 2015 | 08:45 AM
Gan-san's Avatar
It is imperative you do bolt ons (turbo back, bigger IC & UICP) and maybe consider E85 (bigger injectors & upgraded fuel pump) if you want to be safe and reach the full potential of the 3071r. Just curious on why you did not choose the GTX instead?
Old Dec 30, 2015 | 12:00 PM
I got the Garret. Direct bolt on !
Old Dec 30, 2015 | 12:03 PM
Yes I'm getting fuel pump and injectors. All the rest later as well ! E-85 is kinda hard to get in Virginia where I live so I won't be going that route. The closest gas E-85 station is about 2 hours away. I couldn't go over 2k for the turbo.
Old Dec 30, 2015 | 12:07 PM
I talked to my tuner and he said they spool about the same. The GT can make more power so I went that route. I didn't want to build the engine at first but had a change of heart lol. I'm getting all the necessary bolt ons as well
Old Dec 30, 2015 | 12:08 PM
I went stand GT. Did I make the wrong decision?
Old Dec 30, 2015 | 12:20 PM
Yes, you want the GTX. The compressor is much better.
This is that turbo VS an FP green, which is the same as an MHI 18k. I would still go with an 18k.
https://www.evolutionm.net/forums/ev...t-gtx3071.html
Old Dec 30, 2015 | 12:41 PM
Damn I already bought the standard GT. I should've went a few extra hundred bucks for the GTX. More spool would be nice. I'll see how it goes. I'm install and get it tuned and all. I'll just end up getting the GTX or FP red
Old Dec 30, 2015 | 12:51 PM
Did it ship yet? Call the place you ordered it from and see if you can get the GTX..
Old Dec 30, 2015 | 01:09 PM
Yeah it shipped already
Old Dec 30, 2015 | 01:30 PM
RazorLab's Avatar
You will be disappointed with the GT version compared to the GTX version. Spools slower, less power, less response.
Why they even sell that turbo anymore now that the GTX exists I have no idea.
Personally I would return it and get the GTX.
