3rd Gear Synco / New Evo owner
Old Sep 14, 2016 | 12:27 PM
prosperianson's Avatar
Hi everyone,
So I am new to the Evo X, but I will picking mine up hopefully this week. I am being told from the previous owner that the 3rd gear synco has started to get a little rough. I did some calling around to some local shops and I keep being told it's roughly a 2k fix. To me that seemed a little high but like I said I am new to evo x.
So I called Shep Transmissions to get their thoughts on it, since they built the transmission that was in my 1g eclipse years and years ago and they pointed out that their rebuild option with labor is about $1800.
My question is, is 2k right for replacing a worn out synco and if it is why shouldn't I just send the tranny to shep for a full rebuild?
Also if anyone knows of any Evo friendly shops in central Pa, I would love to hear them. I know of Don's and CBRD but thats it.
Thanks a head of time!
Old Sep 14, 2016 | 12:39 PM
LetsGetThisDone's Avatar
When you call a place on the phone, they're probably quoting for removing and reinstalling the trans, as well as replacing the part.
Notchy 3rd gear on the X's is pretty common. I would drive it to see how bad it actually is before spending any money on it. Then if you think it needs gone through, send it to TRE.
Old Sep 15, 2016 | 06:50 AM
hoobastnk90's Avatar
yea I would agree I would drive for awhile to see if its really bad, also maybe freshin up the fluid to see if that helps. Once they start to go really bad generally it will start to pop out of gear on its own.
Old Sep 15, 2016 | 09:56 AM
Awesome thank guys! I will definitely wait and get the car first to see how things look. Thanks for the help.
Is this a common issue on the X?
Old Sep 15, 2016 | 01:37 PM
splattj's Avatar
My 3rd gear in my '15 with 13k miles on it is notchy too. I'd say it's probably common.
Check it out and see how it drives. If it's not blocking gears just put fresh oil in and keep driving.
$1800-2500 for a full rebuild (not including R&R of the transmission) is pretty fair. A lot of clips, pins, bearings, seals that you shouldn't re-use and it has to come all the way apart to replace 1 synchro. If you do it, just shell out the extra for a full stock or better rebuild.
Old Sep 15, 2016 | 01:38 PM
It's so common, I probably wouldn't even call it an issue so much as its just the nature of trans being kind of a notchy turd...lol
Old Sep 25, 2016 | 01:32 AM
MajorMarvel's Avatar
I had my Xs syncros redone earlier this year. It cost me about $400 in parts and around 1800 in labor. All in all I am very pleased with the result.
Old Sep 26, 2016 | 06:30 AM
splattj's Avatar
You can get a full (stock) rebuild from TRE/Shep/Jack's for ~$1500 $2200 is well on the way to built trans!!
rheindollar
16
Apr 3, 2012 02:01 PM
dtuned
Jun 4, 2009 02:02 PM
BMWE30
Apr 25, 2005 09:51 PM
