MAP Clutch Master Cylinder Issues.
Old Jan 29, 2017 | 10:26 AM
TeamEmperor-'s Avatar
I can not get this system to bleed for the life of me. I have bleed hundreds of clutches. I have tried all methods but a power bleeder. I can get it about half way Bleed. With the aluminum boot screwed all the way down it doesn't engage all the way about 1 inch from the Clutch pedal switch still with what i can get bleed. Im super ****ing frustrated. Is there some magical way you need to bleed the clutch system on the evo x? Install was a total pain in the ****ing *** too. Getting those 2 bolts off total pain and getting the ****ing nut on the new one also a pain.
And no there isnt any leaks. Seems to bleed almost, i get pressure after bleeding the old style way for about 30 mins. If i use a hand bleeder it always pulls air but I suspect the bleeder doesnt seal perfect on the slave
Old Jan 30, 2017 | 03:38 AM
Dross99_si's Avatar
Did you opt for the OEM CMC or did you go with the aftermarket?
Old Jan 30, 2017 | 10:07 AM
yes aftermarket as I did not know the OEM meant a evo 9 one. I thought it was another ****ty plastic one. Is the aftermarket one not going to work? Why even sell it if it doesnt work ...gonna go try to bleed again in a hour but if its not gonna work
Old Jan 31, 2017 | 06:30 AM
Dross99_si's Avatar
I only ask because I've seen many posts about people having issues when they opt for the aftermarket one. I mean it should work, but you know aftermarket quality sometimes isn't the best. I used a Motive speed bleeder and then finished it off with a traditional pump and dump method and don't have any issues. I wonder what the problem is?
Old Jan 31, 2017 | 12:11 PM
The clutch fork poped off as well when the slave blew out when the master blew. Very VERY VERY VERY ****ing annoyed with the evo X. Now i have to pull the trans and put the TOB and clip in proper place. Gonna purchase the MAP overextender blocker thing
Old Jan 31, 2017 | 01:08 PM
LetsGetThisDone's Avatar
Just get the ACT monoloc. No need for the over extender deal with the monoloc.
Old Jan 31, 2017 | 01:32 PM
https://www.maperformance.com/produc...FYJpfgodNUsB0g this? I do like that much better, instead of adjusting that blocker all the time
Old Jan 31, 2017 | 03:39 PM
maperformance's Avatar
Sorry... just noticed you got the original issue sorted!
Old Jan 31, 2017 | 03:40 PM
That monoloc seems to do the trick... much harder to get to fail/pop off!
Old Jan 31, 2017 | 09:02 PM
Yeah that. No clip to pop out, so it pretty much can't fail unless it breaks. But it's spring steel, so that won't happen.
MisUnderStood
48
Oct 3, 2017 07:57 AM
kusk8
Jun 7, 2017 05:08 PM
flyingscot
Jan 15, 2013 09:41 PM
Rasputin
Lancer Tranny/Drivetrain Tech
31
Jul 16, 2012 07:04 PM
joyce1bro
Jul 20, 2008 02:06 PM
