Need Some Advice/Input on Mods
Old Jul 6, 2017 | 02:00 PM
2012evogsr's Avatar
Hey guys. I am looking to upgrade my stock Intercooler and Fuel Injectors and wanted some input.
My current Mods:
Injen Intake w/UICP
Tomei Titanium Turbo Back w/ Test Pipe
Grimmspeed MBC
Wideband Air/Fuel
Tuned at 22psi (road)
I am looking to get the ETS 4" intercooler and FIC 775cc injectors so I can increase boost a little more. I understand I have to have a re-tune afterwards but was wondering if I increase boost, do I have to replace/upgrade the stock bov. I heard they can hold about 25psi.
The car has never been on a dyno but anyone out there with similar mods know what #s I should/could expect once the new FMIC/Fuel Injectors are put in maybe at about 23-25psi?
Any input is greatly appreciated.
Thanks.
Old Jul 6, 2017 | 02:49 PM
LetsGetThisDone's Avatar
No need for injectors on stock turbo unless you want to run E85. If you're running out of fuel, check the fuel pump relay, and/or replace the pump with an ASNU 330 pump. 3.5" intercooler is plenty big for up to ~800whp, no need for a 4".
Ditch the MBC, and use an EBCS. The X has really good boost control strategies, no reason not to use them. Stock BOV is fine for the stock turbo.
Old Jul 7, 2017 | 06:03 AM
2012evogsr's Avatar
Ok sounds good. Thanks for the input.
Old Jul 17, 2017 | 11:16 PM
PatricksEvilEvo's Avatar
My 08 made 340/345 @ 25psi with basically the same mods. Only other mods I have are a buschur intake and fuel pump. I don't see an IC being beneficial unless you're planning on going past 25-27psi and want to run ethanol. In which case go with FIC 1100s and a 3.5" core.
Koroshiya
12
Jun 6, 2017 10:38 AM
Risky Guy
Apr 18, 2013 10:13 PM
backdraft420
Jun 27, 2011 12:12 PM
RedLanEVO
May 14, 2008 07:42 PM
