Sakura intake and Synapse BOV installed correctly?
Old Jul 29, 2017 | 09:43 PM
X2jesse1x's Avatar
I resently purchased an 08 GSR with a Sakura intake and Synapse BOV. Well I'm running "lean" and I Just want to see if this thing is installed correctly.
Also what is that tube going to that leads to a thing with wires?
Old Jul 30, 2017 | 03:52 AM
4b11slayer's Avatar
To me it looks reversed. Ive never dealt with one tho.
You can remove it and look at the actual valve inside. That should tell you what way it goes.
The sidewith the plunger should be on the boost side. And the side with the top of plunger should face intake pipe.
Old Jul 30, 2017 | 09:33 AM
RazorLab's Avatar
Is the car tuned for the intake? If not, the MAF scaling is off and that is why you are running lean.
The BOV the wrong way or not wouldn't make the car run lean or rich.
As far as the box, this literally took me 3 seconds searching on google for "SEN-P70B"
http://www.veisystems.com/old/sen-p70b.html
Old Jul 30, 2017 | 09:51 AM
X2jesse1x's Avatar
Unfortunately I have no idea if it was tuned previously. The guy I bought it from said it had but needed retuned, idk wether he was just telling me that because it had never been tuned or because it actually needs retuned.
Old Jul 30, 2017 | 09:52 AM
X2jesse1x's Avatar
yeah I googled it after posting the thread. I guess that explains the gauge on the steering column.
Old Jul 30, 2017 | 09:55 AM
RazorLab's Avatar
Absolutely need to tune it for a larger MAF intake.
Old Jul 30, 2017 | 12:30 PM
X2jesse1x's Avatar
Ok I just have to find a decent etuner. I plan on eventually getting a pro tune but I need to fix the issues first so I can get it through emissions.
Old Aug 3, 2017 | 01:57 PM
wrx lol's Avatar
Check Synapse for cracks.
Old Aug 3, 2017 | 03:59 PM
LetsGetThisDone's Avatar
The synapse DV can be installed in either direction.
As razorlab said, the car very likely needs a tune.
Old Sep 3, 2017 | 07:29 AM
Jaraxle's Avatar
What is this thing you call Google?
tjwphoto
22
Feb 22, 2014 08:07 PM
SlowSRT03
Nov 11, 2013 06:25 PM
kaczordd123
33
Aug 13, 2012 09:22 AM
elmark44
Jul 27, 2011 11:46 AM
KZEVO
Jul 17, 2005 11:21 AM
