Does a Comprehensive E85 write up exist??
Old Jul 23, 2020 | 11:48 AM
  #31
Blue_Lion's Avatar
255 should be fine on a stock turbo, if your planning on bigger though then it will need to be upgraded again.
ill do that then. start with the 255 and then upgrade again later when the time comes like you said. thanks biggie.
Old Jul 23, 2020 | 12:28 PM
  #32
LetsGetThisDone's Avatar
Originally Posted by Blue_Lion
you must have not seen the subject title....
Ok. Why bother with the expense of cutting up the stock fuel pump housing and buying parts to adatp in a walbro 450 or 255, and then have to install and aftermarket inline fuel filter when you can just buy a drop in pump that will make the power you're looking for?
I'm trying to help you make smart choices with this, but i guess one can only lead horse to water...
Old Jul 23, 2020 | 05:28 PM
  #33
Blue_Lion's Avatar
i get that man. and i appreciate it. but its not that i dont want your help or that im choosing to ignore your advice its just the shop that will be tuning my car gave me the option of the two that i mentioned.
Old Jul 23, 2020 | 05:52 PM
  #34
So you're using a shop that's making you spend money that you don't need to?
Sounds like a great place to go..
Old Jul 23, 2020 | 05:53 PM
  #35
Blue_Lion's Avatar
ill run the asnu 330 buy them and see what they say. thanks man
Old Jul 26, 2020 | 03:18 PM
  #36
Matthew Blunk's Avatar
I just bought a kit, not a pump by itself. That being said, it came with a walbro pump and a new pick up screen/ filter that retains the factory set up. Also came with a hanger adapter that dosent require cutting up the factory one.
Old Aug 8, 2020 | 07:43 AM
  #37
Fuel hose
So , the fuel line that connects the right and left side of the tank. The rubber hose that's in the tank, connected to the bottom of the fuel pump, and goes to the right side of the tank.
Did you guys upgrade or replace that when u switched to E85?
My kits all installed, car runs great. But I did notice when I installed the pump, that that bit of rubber hose was already slimy, like it was deteriorated already. And I'm sure E85 isn't doing that hose any favors.
Just wondering what everyone thought
Igaly1021
Jan 1, 2015 04:27 PM
Scoobyevo9MR
Sep 24, 2013 03:07 PM
dangle
Jul 14, 2012 06:46 AM
boostless
E85 / Ethanol
36
May 17, 2012 07:30 AM
PeteyTurbo
E85 / Ethanol
12
Jul 7, 2008 07:15 PM
