Stripped transfer case bolt
Old Jul 29, 2025 | 04:53 PM
jacob_rausch_'s Avatar
Angry Stripped transfer case bolt
this is the bolt which felt like it stripped, shown in the old transmission
After fitting a new SST into my 09 ralliart (Old one was shot) as I tried to reconnect the transfercase, the one long bolt that sits under the turbo heat shield and goes through the transfercase felt like it immediately stripped the threads inside the trans bellhousing as soon as I put any sort of torque on it. What are my options? I assume i’ll somehow need to make new threads, but how should I do that and will I need to remove the transmission again to fix it, or is there a way to do it in the car? I’m in a bit of a rush as the car needs to be out of the driveway soon. Any help is greatly appreciated.
Old Aug 3, 2025 | 07:25 PM
deylag's Avatar
You can repair this by using a heli-coil or time sert kit.
koolzero
Mitsubishi TC-SST Discussion
Mar 24, 2020 07:25 PM
Brandon Robblee
Dec 27, 2013 05:05 AM
eXtreme-Speed
Aug 20, 2012 10:54 AM
marcusE
11
Dec 13, 2011 08:51 PM
AngryEvo8
May 10, 2011 03:42 PM
