Sponsored by:
Sponsored by: CARiD
Going over bumps, display flicker/error.
Old Mar 28, 2008 | 12:49 AM
628's Avatar
628
Starting yesterday I noticed something weird with the red digital display between the two gauges when I was going over bumps. It would have some sort of error/flicker. I'm not sure what it says as my eyes don't necessarily belong there when driving, but I believe it turns yellow from red. From a glance, it looks like the "STEERING WHEEL LOCK" error.
But anyway, anyone else?
Old Mar 28, 2008 | 12:55 AM
Mightygnu's Avatar
Nop, never heard of this happening either. Kind of odd.
Old Mar 28, 2008 | 04:34 AM
Jonasan50's Avatar
Like the flickering dash lights in the VIII's... Then they go out completely??!! That sucks.. Get it checked... But if you have tints on the car, Mits will void the warantee...
Old Mar 28, 2008 | 10:41 AM
DJ_Bboy's Avatar
okay i get this also, but i live in a place that we get winter and mine always for no reason even theres no ice or snow on the ground it turns yellow and says "possible icy roads" and turns back again bout 3 seconds to normal red display. try to see if you can glance quickly and read what its say or warning.
keep us updated!
Old Mar 28, 2008 | 10:57 AM
628's Avatar
628
keep us updated!
Yeah, that may be what's popping up. I'll try to...uh, recreate it..
WHAT?!
Old Mar 28, 2008 | 10:58 AM
EvoXstylin's Avatar
keep us updated!
it's doing that because the outside air is 37 degrees, it always does it.
Old Mar 28, 2008 | 11:03 AM
Noize's Avatar
EvoM Administrator
Its a traction limited warning. I've gotten this when going into a turn a little hot with ASC in normal mode.
EvoXstylin's Avatar
Originally Posted by 628
WHAT?!
haha he's just messing with ya
Old Mar 28, 2008 | 11:15 AM
PDXEvo's Avatar
Im with Noize on this one. Sounds like you are getting the traction screen. Another possibility is, if you have FAST keys, that your key is getting out of signal range, or something like that.
Old Mar 28, 2008 | 01:15 PM
Robevo RS's Avatar
we already try that. the display say something like warning key or like that. nothing like what he described.
if you start the car and get out with the key actually i can drive the car away, with the warning display on. Its weird.
Old Mar 28, 2008 | 04:46 PM
Jonasan50's Avatar
But the car will eventually shut down when the car stops somewhere.
Old Mar 29, 2008 | 12:40 AM
Joe's Evo X's Avatar
if you were going over bumbs then it sound like you traction control came on for a split second. Also if it drops below 37 degree i beleive, it will show possibly icy road. hope this helps
Old Mar 29, 2008 | 06:04 AM
scottatyamaha's Avatar
Ok had something similiar to this happen to me this morning. I was pulling into a parking lot that had a ruff entry and a uphill incline and the digital display went to the yellow screen really quick and I could not see what it was saying. I know it was not traction becuase I was going slow as to not scratch the front lip of the car the only thing I think of was the low fuel indicator because I am running low on gas. But usually when the low fuel indicator comes on it dings also. Are you low on gas when this is happening?
Old Mar 29, 2008 | 11:05 AM
UFO's Avatar
UFO
That's definitely your traction control. Every day at work when I pull into the parking lot at work it comes on and cuts power. I've actually gotten into the habit of turning ASC off before I pull into the garage. It's not like I'm hauling either as I work downtown and pull in at 2 or 3 MPH.
Old Mar 29, 2008 | 12:07 PM
That thing must be crazy sensetive.
Ev0la
Nov 3, 2016 07:15 PM
mitsumaster
Nov 14, 2015 07:55 AM
justindxin
Toronto Lancer Club
24
May 16, 2010 04:58 PM
strtrcng426
Dec 1, 2008 09:40 PM
schleppy
Jun 28, 2004 08:15 AM
