Sponsored by:
Sponsored by: CARiD
Painting the tail lights
Old Jun 29, 2008 | 08:34 AM
qubit's Avatar
Has anyone done this yet? (painting the red plastic molding, not the entire light fixture) This needs to be done IMO to separate the X from the base lancer. Options im thinking of include black, gray, or color-matching (blue for me). Hell you could even do carbon fiber if you had the knowledge.
I took one of the lights out and looked it over. They appear to be 3 pieces, a red plastic molding, the clear plastic covering, and the actual light reflectors. It looks like the lights are clipped into the red molding, and the clear plastic is just glued on top.
I know on most cars it is possible to disassemble the tail lights by removing them, and placing them in a 250 degree oven for 3-5 minutes. This is supposed to heat up the glue enough so that it can be removed. once you are finished painting you are supposedly able to re-heat the glue up, and just press the tail light back together.
My concerns: i'm afraid the lights will end up with moisture in them, or accidentally char my lights.
Old Jun 29, 2008 | 08:55 AM
macPSU's Avatar
Why couldn't a base Lancer owner just do the same thing?
Old Jun 29, 2008 | 10:12 AM
Sa7aN's Avatar
tail lights are melted together i belive... you would need a dremil to get them apart
Old Jun 29, 2008 | 12:00 PM
FireFighter2968's Avatar
Buy ralliart tail's.....
http://www.caranddriver.com/var/ezwe...mage_large.jpg
Old Jun 29, 2008 | 01:27 PM
qubit's Avatar
how sure of this are you? Most tail lights can be separated by heating them up and inserting a wedge. For example, how to do it on a prelude: http://92lude.com/tailight_conversion.htm
Old Jun 29, 2008 | 01:59 PM
JoeyM3's Avatar
the RA ones are nice, sam posted pics of another RA which doesn't have the same tails
Old Jun 29, 2008 | 02:22 PM
Thats the pre production version
The silver one pictured above is a production model
Old Jun 29, 2008 | 03:18 PM
blanknotice's Avatar
I already tried this. Snapped off a piece of the housing in the process. They might be melted together, but from what I saw the edge where they connect isn't accessible. The front lens is sunken into the rear housing, so you cannot get a flathead or anything in between to pry them apart. I too am waiting on Ralliart tails...
Old Jun 29, 2008 | 04:45 PM
EvoXstylin's Avatar
What will the aftermarket area bring? Just as long as their not those crappy "euro" lights.
Old Jun 30, 2008 | 11:51 AM
SilentSLJ's Avatar
Amen!
digdat
Jun 25, 2014 07:58 PM
ezzey
Nov 29, 2010 01:16 PM
kingman4
19
Apr 18, 2008 07:02 AM
144mph
Oct 7, 2006 08:54 PM
EvoVIIIGuy
10
Nov 14, 2004 03:18 PM
