Sponsored by:
Sponsored by: CARiD
hood latch broke on x
Old Aug 30, 2008 | 08:39 PM
  #31
Dann08's Avatar
i picked up my MR on the 6 of AUG and my hood latch broke today! so it seems to be a prob on both models
Old Aug 30, 2008 | 11:19 PM
  #32
Timujin's Avatar
Gas pedals and hood latches...two things that should NEVER break on any car.
rant.
Old Aug 31, 2008 | 11:02 AM
  #33
SpeedI2acerX's Avatar
what do you do after it breaks? can you not open it anymore until its replace?
Old Dec 15, 2008 | 01:05 PM
  #34
_Chris_'s Avatar
Mine finally broke. Taking it to the dealership tomorrow.
Old Dec 15, 2008 | 03:47 PM
  #35
wongck's Avatar
I may just break mine on purpose before my warranty expires just to get it fixed...assuming it won't break naturally by then
Old Dec 15, 2008 | 03:55 PM
  #36
Red Dragon's Avatar
Spray some lubercating grease on the latch and the moving componets. It helps out alot.
Old Dec 15, 2008 | 04:04 PM
  #37
Mitsutech56's Avatar
Anyone with a stiff hood latch should bring their X in to the dealer. Product engineering WAS asking all dealers to submit what they find to improve the parts. From the ones I saw, the cable is binding and has nothing to do with the latch or handle.
Old Feb 8, 2009 | 09:05 PM
  #38
smgevo's Avatar
Mine broke again. Can't open the hood even after the tech bulletin had the entire cable routing and parts replaced a few months ago. Even after the repair, the hood was very hard to open by pulling on the handle. The handle is still intact, but the metal bracket that holds the handle is bent 45 degrees (I took off the plastic panel) Can't even pull the cable with pliers to open the hood. That is twice in 6000 miles and only a few dozen openings. Handle should pull front to back rather (verticle) than sideways pull for leverage.
Old Feb 8, 2009 | 09:15 PM
  #39
qu evox's Avatar
i thought i was going to break mine this weekend. It was VERY cold out and i feel like the line was almost frozen. The i unfortunatly just pulled the lever hard and it finally let go and the hood open. I was nervous as well though.
Old Feb 8, 2009 | 09:41 PM
  #40
RobertRA's Avatar
If it is hard to pull, dont break it, just ask someone to push the hood down a bit, and then pull the latch, it will open quick.... do that untill u go to the dealer
Old Feb 9, 2009 | 04:25 AM
  #41
aftershock141's Avatar
I feel like my hood latch is about to break as well...uhgg.
Old Feb 9, 2009 | 04:39 AM
  #42
THEMEMPHISFORCE's Avatar
Mine did the same thing, I had it two days and took it back to the dealer, they had to order a new cable and took them around 2 hours to do it. They said the stock cable is too long and can break. Now it works like a champ.
Old Feb 9, 2009 | 09:54 PM
  #43
smgevo's Avatar
pushed down on the hood while someone pulled the cable, and it opened Once you pull on the cable by yourself and it does not open, if you push on the hood, you hear a "click" which should be the latch engaging the hood loop. Even doing this will not open the hood when you pull the cable again by yourself. I repeated this six times and it would not open. You must have someone press down on the hood like you are going to dent it while the cable is pulled at the same time and it worked another six times in a row. The cable looks fine and once the hood is opened and you pull the cable, all looks good and functions fine. There must be something wrong with the latch mechanism. Going to the dealer tomorrow.
Old Feb 11, 2009 | 09:49 AM
  #44
neveronlineten's Avatar
Mine is a pain in the @$$ to open and I know it will eventually snap. I will talk to the dealer about it next time I'm there.
Just an FYI if you have someone gently push down on the hood when pulling the lever it makes it open easier . Not that popping the hood should be a 2 person job, but it may buy you time till you can get it fixed
Old Feb 11, 2009 | 09:34 PM
  #45
turizmo01's Avatar
I had the same problem. It got harder and harder to pull open. I had to have someone push down on the hood to get it open so I took it to Mitsubishi and they replaced it under warranty.
