Sponsored by:
Sponsored by: CARiD
Evo X MR Dyno Results- Stock
Old Sep 27, 2008 | 12:10 PM
  #31
Hiboost's Avatar
Originally Posted by heavyD
Interesting because the Ralliart has been dynoed at 222 whp;
http://jdm-insider.com/Blogs/Eric/?p=1054
All dynos read differently so that number won't compare directly unless both cars were run on the same dyno. Likely the car detecting a loss of traction because of the rollers spinning at slightly different speeds is what is causing the MR's to get inaccurate numbers.
Old Sep 28, 2008 | 04:49 PM
  #32
NG12's Avatar
Those guys from D-Sport dynoed a stock GSR at 271.4 whp. The article evens states the Evo X made 40-50 more whp than the Ralliart.
There really needs to be more of a standard between all these dynos. I'm wondering if I owned a tuning shop with a dyno that read higher than the guy down the street if I'd get more business just because some people put so much faith in these numbers.
Old Sep 28, 2008 | 06:40 PM
  #33
ODUB's Avatar
Originally Posted by Sean@Iveytune
stock 10 mr does 238 on my dynojet.
Sean
what did the IX MR's do on your dynojet?
Old Sep 28, 2008 | 06:50 PM
  #34
fastkevin's Avatar
An auto trans chews up more power than a manual..
With an 8.x AFR however, you're not gonna make good power with anything. Factories tend to set AFR's lean in the low rpm, where they're tested by the gov'ment, and set them fat on top, so there's not a snow-ball's chance in h*ll of warranty claims from holed pistons.
Easy enough to rememdy...
Evoguy!123
Nov 19, 2016 02:12 PM
JrEvoXnitez
Evo X Dyno Results
May 14, 2014 09:32 AM
EVOGOD21
May 13, 2010 09:39 AM
jfh
Nov 4, 2003 01:50 PM
DynoFlash
55
Oct 13, 2003 07:21 PM
