Evo X Steering Wheel Hub Extender
Any updates on this guys? I hate the seating position in the X. Please tell me there is another solution. Or do I have to drive to Washington State and pay $800 for that custom 1 3/4 inch extension fabrication as stated in this thread?
I shipped my steering column to Kito last year and he did a great job. I think with return shipping it cost about $400. I probably spent another $100 on shipping it to him, packing materials, and random other stuff. This is the best mod I've ever done. I think he got me closer to 2" but I can't remember exactly. Perfect spacing for me now on the street or track. My road course brake modulation is so much better now that I can sit far enough away from the pedals. I highly recommend contacting Kito. He did really quality work and he turned it around fast for me. Taking it out and putting it back in isn't bad provided you have the service manual.
How long does it take to break down and assemble the steering column? What if I have no idea what im doing? Maybe ship the car in a container to Seattle? Or is it cheaper to drive for 4 days?
You can easily break it down in one weekend, and put it back together in one weekend. It was not difficult. I combined this with installing 4 point Schroth harnesses and running a wire harness for a backup camera so I had my interior completely gutted, and it's my weekend car so I did not need to rush it back together so I did it over several months actually. I really don't remember any difficult issues with the removal or reinstallation. I did need a 3/8" torque wrench because I could not get my 1/2" in there to torque the bolt between the shaft and the steering box. Basically everything you need to know is in the Maintenance Manual and one awesome How-To someone did on adding Bluetooth (It showed how to take the wheel off better than the manual). If you change your own oil and do your own brake jobs this will not be hard for you. Most time consuming part was removing the plastic wire support stand-offs from the electrical harnesses and re-positioning them to get the wires re-run cleanly. The wires were all long enough but I seem to recall I had to skip one of the stock support locations to make it clean and not pull them too tight or bend them at too tight a radius. Hardest part of the whole job was figuring out how to get the ignition shift lock cable all back together, as a little "tetrus" piece dropped out before I could see where it came from. If you have a GSR you might not even have that cable.
I'm 6'2" and to get close enough to the wheel to satisfy my HPDE instructors I had to get my seat so close to the dash that my legs were folded into the car at bad angles. It made smooth pedal modulation difficult at best, and by the end of the weekend my knees hurt really bad. First time out after the extension (and the belts) and my instructor complemented me on smooth pedal modulation. I know the belts made a huge difference too, but the comfort and ability to move my feet cleanly really all came from the wheel position change.
I think his shop was closed back when I had him do the work, but I was able to find him using google. He was working for another shop at the time. I'll try and look for his e-mail, I think I have it in my work computer.
As you'll find out, this is not the easiest of problems to solve. If it is just a minor inconvenience for you I'd say live with it. If you're like me, I couldn't drive the car comfortably on the track (the very reason I bought the car) so I needed a solution. I would have preferred a more elegant approach such as the telescoping column you referenced, but I would have had to blaze an expensive trail that possibly would have produced a non-solution. Given that choice I would have either procrastinated and never done it, or I would have wasted a ton of time and money. But Kito, and the original guy that brought his car to Kito and posted on this thread had already blazed the trail to a working solution that didn't cost too much money. It was a proven solution I was comfortable with, and I didn't really need adjustability for multiple drivers because my wife will never drive my EVO. It worked awesome for me.
I know if I ever sell my EVO I will be buying a stock column and taking mine out, for fear of liability issues if the idiot after me crashes and is too close to the airbag, and because if I ever were to get another EVO X I could swap in the extended column again for free.
Honestly, the simple solution is to ditch the airbag and get an aftermarket wheel and hub extender, but I wasn't willing to give up the safety of the airbag in such a small vehicle. I've been saved by airbags before, and I could not possibly think about removing one on a vehicle that would see a lot of street driving.
