Sponsored by:
Sponsored by: CARiD
AMS Shop TIME ATTACK EVO X build Thread!
Old Nov 4, 2008 | 03:28 PM
  #181
hova00's Avatar
Any update on the turbo kit for the X?
Old Nov 6, 2008 | 09:19 AM
  #182
lynxo23's Avatar
love it
Old Nov 6, 2008 | 10:02 AM
  #183
compscibOi's Avatar
Hey AMS,
Any information from your end about the "Baddest Lancer Evolution Challenge" ?
Old Jan 7, 2009 | 03:15 PM
  #184
RichK@AMS's Avatar
It seems like this thread is long overdue for an update... my apologies.
I am not sure if you guys follow the build thread in our section, but the car has once again gone under the knife as its currently being transformed into a full unlimited AWD Tiem Attack race car.
Here are some pics of the car from the Super lap battle event.
Old Jan 7, 2009 | 03:22 PM
  #185
RichK@AMS's Avatar
after the race the car went from this:
to this
Here is a video of how we did it
AMS TA-X tear down video
and the fully stripped down chassis went of to get acid dipped
December 12, 2008
After acid dipping
Ivan working on removing some of the unnecessary brackets from the chassis.
One down...plenty more to go!
The build progress as of December 18, 2008
Old Jan 7, 2009 | 03:31 PM
  #186
RichK@AMS's Avatar
A quote from the other thread about the build
Originally Posted by Ivan@AMS
Sorry guys. It has been hectic here. Having nearly a week off between Christmas and New Years holidays and then inventory.... anyway...
With the help of Shane and Shaun, we have been able to get quite a bit of weight off the chassis. The running total of weight removed is 153 pounds in the boxes and ? pounds in the vacuum cleaner. Unfortunately, some of that weight is going to go back in (trunk floor, rear seat area floor and lower core support) but it will "net" a loss in weight.
Justin has been working on getting the cage in the car. Planning and fabricating the cage is not going as quickly as we had wanted. We are trying very hard to keep the cage to a minimum while maximizing driver protection and chassis rigidity. We are being very creative with the cage as you will soon see. Keep in mind that we need to incorporate a support for the steering column, mounts for the seat, a mount for the pedal box, and mounts for the fuel cell into the cage structure. We have had several changes in our design that have been taking up a lot of Justin's time but will be worth it in the end.
Justin and I modified the subframes to help correct suspension geometry that is changed with a lowered stance. These both came out very nice. I had to reinstall the rear suspension and make some modifications to the frame rails to get full suspension travel. I am pretty happy with the end result. A 295-35-18 tire will now tuck all the way up till the top of the wheel is even with the top of the wheel well.
I spent a bit of time trying to decide what to do with the rear doors. Doing the normal "gut and cut" is just not going to work for this car. I wanted to do pin on rear doors but I just couldn't find a good way to modify the stock rears that was tasteful. We ended up ordering new rear door skins from Mitsu and I already have one pinned in place. I am pretty pleased with the looks. The door skins are 8 lbs each so this will be a significant weight savings. I wish we could do the same for the front doors....
Here is how the car looks as of today, (January 7th 2009)
The TA-X chassis just chilling on the lift in the fab area...
A little interdepartmental meeting...
Progress of the roll cage build...
Modified rear subframe
Rear suspension mock up...
Ivan and Shaun mocking up the rear door
Justin welds on the tabs that hold the door skin in place
Shaun prepping the chassis for the roll cage
More progress of the roll cage, the seat is jut there for mock up purposes an will actually by mounted way back, behind the b pillar.
Justin working away on the cage.
Rear door with lexan window
bolts securing the door skin to the body
Door skin attachment points
Old Jan 7, 2009 | 03:35 PM
  #187
Alexander's Avatar
holy ****.
how much did the acid-dipping affect the body? was it for weight reduction?
Old Jan 7, 2009 | 03:44 PM
  #188
RichK@AMS's Avatar
Originally Posted by Alexander
holy ****.
Yes, acid dipping was done mainly for weigh reduction also to get the chassis to bear metal so it can be spot welded and outfitted with a cage.The acid dipping process took off about about 30 lbs of weight off the chassis.
Thaks
Old Jan 7, 2009 | 03:50 PM
  #189
vboy425's Avatar
cool
Old Jan 7, 2009 | 04:03 PM
  #190
Robevo RS's Avatar
very good to see the evolution of the evolution in the states. I'm really happy to see how this things going ahead in the Evo scene.
Just simply astonishing job.
Rob
Old Jan 7, 2009 | 07:22 PM
  #191
Skyline559's Avatar
Ams = pro
Old Jan 7, 2009 | 07:28 PM
  #192
nils's Avatar
looks awsome...
Old Jan 7, 2009 | 07:49 PM
  #193
MitsuJDM's Avatar
Be sure to keep this updated!
Old Jan 7, 2009 | 07:56 PM
  #194
CBRD's Avatar
looks good guys,
cant wait to see her done...
cb
Old Jan 8, 2009 | 03:43 AM
  #195
KPerez's Avatar
So you removed ~150 lbs from the chassis some of which you indicated were "unnecessary brackets". Were these brackets for chassis rigidity and did the roll cage substitute for these and other pieces that were removed to reduce weight? In short, you wanted to remove weight but still retain orginal chassis regidity, I assume. To achieve, you removed those pieces that could be substituted by the TT race required roll cage the results of which still yeilded a net loss of weight. Is this correct?
Later, Ken
