Sponsored by:
Sponsored by: CARiD
problem in high RPM's
Old Nov 8, 2008 | 06:05 PM
diddyX's Avatar
I installed my intercooler pipes and aem intake about 3 weeks ago, since then i have had no problems till now. the car drives fine until i get it up to about 4,500 RPM's then when i give it gas the car just sits there......then jerks forward and then repeats again or not and then picks up. samething in 3 gear and forth but only in the high RPM's and when i'm putting the peddle to the floor. Any ideas whould be great. Would a tune fix this?
Old Nov 8, 2008 | 07:09 PM
midwestX's Avatar
clutch
Old Nov 8, 2008 | 07:10 PM
midwestX's Avatar
try to retrace the steps of AEM & pipe incase any fuel pipes or some ting is loosen
Old Nov 8, 2008 | 07:55 PM
STi2EvoX's Avatar
It's the crappy stock tune. That jerky feeling is due to misfires from the overly rich air fuel ratio and yes, a tune will fix this. There was a dealer released reflash that came out to help alleviate this and it definitely helps. The car still hesitates when first getting on the gas after a shift, but it's better. Go to your dealer and get the latest reflash and your problems will be solved for the most part. Or, better yet just go get an ecutek tune to really unlock the power of this car. You'll pick up about 50-60 whp on a stock X. Plus, the hesitation issues will be gone. Just a thought.
Old Nov 8, 2008 | 08:57 PM
diddyX's Avatar
thanks for the help...I took it in for the reflash that was supposted to the problem, makes me wonder in they really did it. I will be send out my ECU next week for a ECUteK. Hopefully this fixes the problem. I have my fingers crossed.
Old Nov 8, 2008 | 09:42 PM
hel_if_ino's Avatar
I like everyones answers, like they are 100% positive that is the problem... I wouldn't say any of the above are the correct answers, your best bet is to trace everything that you installed, see if there is a problem there. If not, take it back to stock and see if the problem disappears... then start adding one at a time from there and figure out what is causing the problem.
Old Nov 9, 2008 | 05:17 PM
diddyX's Avatar
now when the car is in neutral the RPM's bounce just below 1,000. it just bounces and bounces....could a hole in the intercooler pipes cause these problems?
Old Nov 14, 2008 | 04:57 PM
diddyX's Avatar
pretty sure I figured out my problem.....I opened up my AEM box and the filter was just laying there...screwed it back on and done....can't test it out till I get my ECU back....
Old Nov 14, 2008 | 08:56 PM
cush's Avatar
ecu
Old Nov 15, 2008 | 01:20 AM
hel_if_ino's Avatar
I cant say I have ever done that, but I have done worse...
Old Nov 15, 2008 | 01:59 PM
1SiCkEvo's Avatar
I had the same hesitation problem with the stock tune. Once i got tuned on ecutek it definitely went away so i can almost guarantee yours will too. good luck
Old Nov 15, 2008 | 07:08 PM
surferjeff's Avatar
Sounds like the normal misfire at upper rpms.
Old Nov 16, 2008 | 02:11 AM
fastkevin's Avatar
My vote is this is the most likely cause. I don't buy into the stock mapping, 'cuz it wouldn't wait for a few weeks before it started acting up. It was there when you installed your bits, and the car didn't hesitate then, correct? If your filter popped off, you would go really lean, leading to symptoms you described. Same thing could happen if one (or more) of the various hoses loosened up, allowing air in. I'm willing to bet you fixed it, but if not, like what was written, re-trace your install and make sure everything is secure (and in the right place).
Old Feb 4, 2009 | 03:15 PM
xXEVOloverXx's Avatar
i notice that also after i got my intake and upic cat-back,a tune should fix that i think,any update after u got ur ecu back?
Mark Dip Chan
Lancer Troubleshooting
Feb 5, 2023 01:07 PM
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
soldi3rappl3
16
Feb 13, 2008 03:39 PM
RSGuy
10
Sep 26, 2007 08:57 AM
2wenty2
Jul 8, 2005 12:58 AM
