Sponsored by:
Sponsored by: CARiD
where to install wideband?
Old Mar 28, 2009 | 12:14 PM
WTFchuck's Avatar
i was wondering where i should locate the bosch sensor for my wideband
Old Mar 28, 2009 | 12:18 PM
GPTourer's Avatar
I think the consensus is in the DP. If you have to put it under the car, put it above 3 or 9 o'clock, and definitely not at 6 o'clock because water can puddle up and eventually foul the sensor.
Old Mar 28, 2009 | 12:20 PM
gsrboi80's Avatar
In the DP pre cat. Most WB manufacturers reccomend at lthe least 10-12in downstream from turbine.
Old Mar 28, 2009 | 07:09 PM
autobahntom's Avatar
The MXP downpipe has a bung in it already for a wideband. Mine did when it came-not sure if it was supposed to or not as it is/was not advertised that way.
Old Feb 18, 2012 | 01:14 PM
Evolution Z's Avatar
in the AMS dp, there are two bung holes for the wideband, each at a different angle. which one would be optimal?
Old Feb 18, 2012 | 02:44 PM
Get Rad's Avatar
And if you don't have a test pipe, hfc or dp with an extra bung you will have to head to a muffler shop and have one welded in.
Old Feb 18, 2012 | 08:20 PM
SilverJesterGSX's Avatar
I have a speed circuit test pipe that has an extra bung for a wideband (no aftermarket dp yet). Is it better to put it closer (like in the downpipe)? Would putting it in the test pipe be too far away?
Couple of pics for reference:
pic 1
pic 2
RedEvoxGSR
Jun 15, 2010 10:47 PM
chmodlf
Jul 28, 2007 11:09 PM
lancerrally45
May 5, 2007 06:24 PM
spyderx
14
Nov 24, 2006 08:08 AM
evilevo2006
Mar 15, 2006 02:14 PM
