Sponsored by:
Sponsored by: CARiD
FAST Key not so....fast?
Old Apr 29, 2009 | 11:42 PM
  #31
Project_Evo's Avatar
I have the same issue quiet often with it not reacting quick enough. But I just deal with it seems normal.
Old Apr 30, 2009 | 01:09 AM
  #32
WWevoX's Avatar
The time can be set to zero according to the service manual, But it does look like the dealer has to do it.
Old Apr 30, 2009 | 01:31 AM
  #33
EvolvedVIII's Avatar
Unless you are being chased by a a chainsaw wielding maniac the lag time isn't really an issue.
Old Apr 30, 2009 | 09:28 AM
  #34
chopstixx's Avatar
ahhh not funny its happened almost died
Old Apr 30, 2009 | 10:42 AM
  #35
Breakaway's Avatar
Originally Posted by higgs
seems like mine works money when i put my hand over door handle and just kind of pause.... i always have my iphone bluetooth on with me and as long as i'm not going back to it within like 20 secs right after i lock it or vice versa its fine (ralliart 09, assuming same system)
I don't even need to touch the car - the FAST key unlocks the car when I put my fingers between the handle and the door and pause for maybe 2 seconds. When you hear the 'Beep', your hand's already where it needs to be and that's when you pull the handle. I'm pretty sure it's activated when it senses an object in that small area.
Old Apr 30, 2009 | 06:49 PM
  #36
ScottSpeed21's Avatar
OK I just went out to the car to check it out. You can change the settings on the Navi screen from "Off" to "3 seconds" to "5 seconds". Obviously with 3 and 5 seconds there's a delay, but when it's off I can lock the car, immediately grab the handle and it immediately unlocks the car and beeps at me. There literally isn't even a split second of delay with it turned off.
Old Apr 30, 2009 | 06:56 PM
  #37
EvoG8r's Avatar
I have never had this problem. Mine opens with out delay under any circumstance.
Old Apr 30, 2009 | 07:15 PM
  #38
John83's Avatar
fast key has been good to me...except when i forget my key and i go to open my door and i can't. heh.
Old Apr 30, 2009 | 07:38 PM
  #39
UT_Evo's Avatar
Originally Posted by unowned
the door will not unlock if you are wearing thick gloves for example i was wearing my mechanix gloves.
Really? But clearly it isn't heat based... That's lame then.
Old May 1, 2009 | 06:52 PM
  #40
Jblade's Avatar
Originally Posted by antics22
really? i've only encountered problems with fastkey when my remote FOB is sitting in the same pocket with my smartphone...
there seems to be some sort of interference... but when i carry the FOB and my phone in separate pockets, or in different places, its pretty flawless...
+1 only happens when there's interference from my treo
Old May 13, 2009 | 07:58 PM
  #41
onyx1121's Avatar
I went to the dealer, they adjusted the lock/unlock delay time to 0 seconds. Problem still there.
I confirmed its an issue specifically with openning the trunk, then closing it, and going to open a door. I believe it could be due to the FAST key moving from one sensor area to another and needing to be "reacquired" by the car's system.
I'm going to get in touch with Mitsubishi and see what they say and if they can re-produce the problem on another car.
Will update the thread just for documentation purposes when I find more.
Thanks.
Old May 13, 2009 | 10:28 PM
  #42
hfm's Avatar
hfm
i set the timer to 'off' and i still have this problem...
Old May 14, 2009 | 07:39 AM
  #43
Webman's Avatar
There's a setting where you can change the delay from 3 seconds to 0, but I only know how to do it on the NAV display. Though, even with the 3 second delay turned on, I don't ever have this problem, and never had it on my 09 Lancer GTS either.
Old May 14, 2009 | 05:52 PM
  #44
supergengo's Avatar
Thanks.
I'm not sure I'm understanding your issue.
Are you saying you walk up to the car, open and close the trunk, then go to the door and the FAST key does not allow you to open the locked driver door?
Or are you expecting the trunk button to have unlocked the car?
Old May 14, 2009 | 05:54 PM
  #45
supergengo's Avatar
For those who are accustomed to using only 1 or 2 fingers to open the door, I have found that grabbing the middle of the door handle triggers the FAST system more reliably.
