Sponsored by:
Sponsored by: CARiD
Periodic Inspection warning
Old May 18, 2009 | 01:20 PM
Mj23foreva's Avatar
Recently I've been getting this signal every time I start up my car. It just flashes Periodic Inspection on the led screen for a few seconds and then goes away. I tried resetting all my maintenance dates on the MMC but that didnt work. Anyone know how to get rid of this thing?
Old May 18, 2009 | 01:31 PM
628's Avatar
628
I can't remember how to do it...but when I say the service guy do it...it looked pretty complicated.
Old May 18, 2009 | 01:35 PM
Mj23foreva's Avatar
So this is not a common issue? Its considered a CEL?? I thought it was just a maintenance warning...like get your oil changed or tires aligned kinda thing...
Old May 18, 2009 | 01:38 PM
lancer0220's Avatar
read your manual. to reset you do something like turn key to acc then back to off hold info then a screen will pop up allowing you to clear it.
if you cant find it in the manual its somewhere on t his forum. i just played around until i got it to come up, took about 2 minutes to get it down right.
Also this is not a cel , it is simply a maintenance warning nothing to be worried about.
Old May 18, 2009 | 01:40 PM
628's Avatar
628
It IS just a maintenance warning. Nothing more nothing less.
Old May 18, 2009 | 01:41 PM
Mj23foreva's Avatar
thanks, I'll try to find the instructions. So do you know what the exact purpose of this warning is? Its def not something like change oil...
Old May 18, 2009 | 01:50 PM
newcomer81's Avatar
iirc you reset it while in park with the ebrake on. when you toggle though the info button with the ebrake on you get a new menu item for settings.
Old May 18, 2009 | 02:50 PM
628's Avatar
628
The exact purpose of this warning is to make you aware that you are in need of an oil change, or whatever other service is needed at that certain interval.
It comes on like every 3000-4000 miles.
Again...it's really nothing more nothing less. Nothing to be paranoid about.
Old May 18, 2009 | 03:13 PM
Evo Andy's Avatar
Thumbs up
I just reset mine to the next scheduled "maintance".I read the manual.
I have smart key. Key or lack there of does not have to be to "on" position or anything like that.With car off and key to "off" position.Just push the info button to scroll thru the different modes. When you get the screen with the "Wrench"stop.Then simply hold the "info" button down for app 3 seconds till you here a "beep".It will then get rid of that warning and you'll now notice the next scheduled mileage appears in the info center now.
Good Luck,give it a try
Old May 20, 2009 | 08:05 AM
Dimitri13's Avatar
Mine comes on every time I start up too. It's because I got to my 3k mile oil change, and the guy at pep boys didn't know how to reset it I guess.
Old May 20, 2009 | 08:53 AM
Webman's Avatar
You ALMOST have all the info there, but you're missing one crucial step
1. Turn the car off
2. Press the info button til you see the wrench
3. Hold down the info button until the wrench starts to flash
4. press the info button once to reset the maintenance interval (press it twice to increase the maintenance interval to 1yr)
Old May 20, 2009 | 10:02 AM
slo4g63's Avatar
I kept trying to reset it while the car was turned on, didn't work. Then tried it recently with the car off but key on and it worked.
Old May 21, 2009 | 07:03 AM
Evo Andy's Avatar
1. Turn the car off
I was going on memory,opps
Old May 21, 2009 | 10:33 AM
accrane's Avatar
thanks for the info. just reset mine.
Old Jul 6, 2009 | 06:49 AM
Hen5000's Avatar
sweet i remember reading this a while back and didn't remember how to do it. Finally found this post.
mitsubishimanny
Evo X How Tos / Installations
42
Mar 11, 2015 03:45 AM
flx919
Jul 11, 2011 06:22 PM
asng
Mar 6, 2009 12:55 PM
Sofla GTS
Lancer Troubleshooting
Apr 23, 2008 07:08 AM
stefan.bounket
Feb 17, 2008 10:32 AM
