Sponsored by:
Sponsored by: CARiD
What hose is this? --- it fixed my idle
Old Jul 4, 2011 | 12:31 PM
  #31
b3n's Avatar
b3n
Checked mine recently, seemed like it was on there pretty tight. I think I'll zip tie it anyway.
Old Jul 5, 2011 | 04:54 PM
  #32
detroitms3's Avatar
Mine was detached! Fixing this did correct my rough idle issue. Thanks!
Old Jul 5, 2011 | 04:58 PM
  #33
sr20detisbetter's Avatar
Zip ties fix everything!
Old Sep 11, 2012 | 09:19 PM
  #34
gabrod72's Avatar
Sorry to revive an old thread, but I wanted to say THANKS!!!!!!!! This hose had come loose. I had the same issue with my idle fluctuation wildly and had taken it to the dealer once. Even though I asked, they were not interested in pointing out what hose had come loose, but they had "fixed" it under warranty. Happened again, obviously and I took a different path looking here for answers.
Turns out this can really confuse people I think. I had also read about doing a proper reset / clearing codes etc - of which I didn't find any but my service engine soon light was on. Anyway, I flashed it with my AP - and cleared learned memory. What I forgot to do was let it idle for some time after starting it up. It didn't idle strange at first, but when I turned on the AC it started fluctuating again, almost like before but not as crazy. I took it for a spin, hitting WOT pulls to 65 ish a few times and it's all normal now. If idle goes nuts again, I'll check the hose - and if it's still connected, then I'll clear codes/ learned memory and do the proper procedure.
Old Sep 11, 2012 | 11:34 PM
  #35
AFMedic55's Avatar
Mine never blew off but it seemed stupid not to put a $0.20 zip tie on just in case VS a blown motor!
Old Sep 12, 2012 | 06:54 AM
  #36
dcgsr's Avatar
Thanks +1
Originally Posted by SiC
Are you talking about this one?
+1 +1 +1 !!!!
Thanks - my car started idling rough this week - the temps started dropping into the 50's so I thought that maybe it was due to cooler temps or a bad tank of gas.
But nope - this hose was off mine too.
THANKS!
Old Sep 12, 2012 | 12:08 PM
  #37
SudzRA's Avatar
Lol I used a zip tie and a little bit of epoxy around the base of the nipple. It won't come off without a fight now
Old Sep 12, 2012 | 05:12 PM
  #38
thekhmer's Avatar
knock on wood*..mine never came off 2010 gsr w/ 30k and i still dont have a zip tie on it :P but i will put one on today just incase
Old Aug 3, 2013 | 08:15 AM
  #39
johnsonlam's Avatar
Mine came off and I did a silicon hose replacement.
Wrote and article here..
http://www.zerotohundred.com/newforu...post1064374169
This is how it looked like :
Old Aug 3, 2013 | 09:14 AM
  #40
Iowa999's Avatar
Just to be clear, since it isn't in that picture: there needs to be a zip at both ends.
Old Aug 4, 2013 | 07:49 AM
  #41
johnsonlam's Avatar
Thanks.
It's in both ends, just that in that picture, the bottom end is not seen clearly.
Anyway,
Using Silicon hose, it is not as easy to slip out comparing to the stock hose. Cable tie definately secured it tightly.
Old Aug 4, 2013 | 04:18 PM
  #42
Kmasters's Avatar
If so, that's the one that goes to the fuel pressure regulator and if you keep driving with that off at WOT, you'll run lean and it could cause engine failure.
Where is this located??
Old Aug 4, 2013 | 05:32 PM
  #43
Iowa999's Avatar
On the intake plenum.
Open hood. Stand in center in front of the car. Take a step to your left. Look down.
Old Aug 4, 2013 | 05:57 PM
  #44
Kmasters's Avatar
Thanks, my idle would sometimes be a little weird so when I checked it the hose was on tight and ok...I guess the Evo X has some idling issues sometimes?
Old Mar 18, 2016 | 08:13 AM
  #45
andrew_sup's Avatar
thanks
very helpful with pics, thanks again
EVOEvolved
May 17, 2022 08:12 AM
00VIII
21
Apr 15, 2018 11:26 AM
jhkuse
Sep 10, 2016 07:18 AM
Raceghost
Jun 10, 2016 11:28 PM
ezzey
May 9, 2016 09:40 AM
