Sponsored by:
Sponsored by: CARiD
Revs intermittently Dipping
Old Sep 1, 2009 | 08:02 PM
J5isalive2's Avatar
Check the vacuum hose on the fuel pressure regulator.... it is located on the passenger side of the front of the engine. Right under the plastic valve cover, you may need to pull it off to see the hose.
This vacuum hose comes from the factory with no clamps, it WILL fall off at some point and will cause an erratic idle. The hose goes from the intake manifold to the fuel pressure regulator....
Old Sep 1, 2009 | 11:25 PM
jondimellow's Avatar
picture please?
Old Sep 2, 2009 | 07:31 AM
J5isalive2's Avatar
The hose that is right to the left of the dipstick in this picture, a little hard to see. Pull off the Mivec cover and look around.
I will snap an actual picture of the hose when I am near my car in a couple hours.
Old Sep 2, 2009 | 11:34 AM
J5isalive2's Avatar
Posted in another thread.......
Everyone go put a zip tie on this...
Old Sep 2, 2009 | 07:34 PM
DrBump471's Avatar
done! zip tied both ends
Old Sep 8, 2009 | 02:39 PM
rfinkle2's Avatar
i have the same issue
Old Sep 8, 2009 | 10:01 PM
check to see if your air filter is installed properly. sometimes the box isn't closed tightly (bottom) and not having a good seal. to fix this, just unbolt (2 screws and 1 10mm) the front of the intake box, make sure the box is closed correctly, and then bolt it back. this plus reflash tsb fixed my idle.
mister1161
Mar 29, 2016 06:54 PM
svt_lightning01
Nov 7, 2011 08:26 AM
DanJ
Dec 10, 2009 11:52 AM
STi2M3
Jun 27, 2009 06:01 PM
Toxin
15
Mar 14, 2009 12:47 PM
