FYI: 2010 Evo X Plastic Valve Cover
From the AMS website
Product Notes
The AMS EVO X Turbo Kit is NOT COMPATIBLE with the black plastic valve covers found on some 2008-09 and all 2010 models. Aftermarket turbo systems create more heat that can cause the plastic cover to melt, distort or even in some severe cases cause a fire. AMS REQUIRES that all Mitsubishi Lancer Evolution X’s run the aluminum valve cover found on most 2008-09 EVO’s (part number 1035A810) when installing an AMS EVO 10 Turbo kit. This part is available to you at our cost in the drop down options menu below. Please physically verify your cover is not the black plastic version prior to ordering.
Product Notes
See, I told you guys! Eric gave me the info directly after he said the plastic one started to melt when they were testing on the Kids with Cancer Evo X in the Fall. They ended up swapping in a metal one off their shop car so there would be no delays on delivery. That's what I call a great shop, too bad Mitsu made it a pain for 2010+ Evo owners who want to go beyond the factory setup.
Product Notes
Product Notes
Can anyone confirm that the above part# will lend you the the aluminum valve cover instead of the new "possible" plastic replacement?
Thanks,
MvP
When you lift up the plastic Engine Cover, you will see a Valve Cover underneath it. On 2010 cars and newer the Valve Cover is a composite (plastic). On older cars its the traditional metal.
Moore Auto
Evo X Dyno Results
Jun 20, 2019 03:03 PM
FS[West]: Radium Cankcase Catch Can
lbcevo
Aug 29, 2015 05:17 PM
Vostok 7
12
Sep 5, 2011 07:46 AM
