Sponsored by:
Sponsored by: CARiD
Replaced steering wheel now service required
Old Dec 26, 2009 | 07:38 AM
Yousef's Avatar
hello
I replaced the steering wheel with MOMO team 300mm, it did not clear the shift piddles because of the short hub adapter, so I put back the stock steering wheel.
as soon as i moved the car i got service required and ASC went off, I am 100% sure i put back everything as it was..
hmm any idea?
Old Dec 26, 2009 | 07:45 AM
MicMcKee's Avatar
You tried pulling the code?
That would help narrow it down...
Old Dec 26, 2009 | 07:49 AM
Yousef's Avatar
yes i did and there was no codes
Old Dec 26, 2009 | 08:00 AM
boostin20's Avatar
Did it instantly come on before you drove it? The fact that it has no codes makes me think it needs some type of relearn cycle. Try driving it and see if it clears itself.
Old Dec 26, 2009 | 11:06 AM
wiretap's Avatar
Unplug negative terminal of the battery, tap your brakes, then wait 5 mins.. plug back in the battery and see if that fixes it.
Old Dec 29, 2009 | 06:47 AM
Yousef's Avatar
yes instantly even in acc. , i tried off-on for a dozen of times with no luck
no it did not fix it
Old Dec 29, 2009 | 07:14 PM
Yousef's Avatar
ok when I turn on the car I instantly get ACS off and sliding car icon with service required, when I move I get 4 wheel drivetrain icon with service required
do you think it is safe to drive the evo?
Old Dec 30, 2009 | 12:57 AM
Arutha's Avatar
im having the same warning with my evo at the moment due to a transmission problem. my mechanic replaced the clutches but i still have the warning. im off to see mitsu next week when everything re opens but until then i don't touch the car. not really any help to you but if you can find a way to turn off the warning let me know
Old Dec 30, 2009 | 01:55 AM
Yousef's Avatar
I am driving the car, performance wise nothing changed
could it be something electrical!!! hmm maybe
Old Dec 30, 2009 | 03:17 AM
EndlessRed's Avatar
it can be electrical related. i tripped the same warning/error when i wired leds into the brake lights. why? no idea.
if that's true, maybe your steering wheel position sensor is messed up?
Old Jan 1, 2010 | 06:38 AM
Yousef's Avatar
rechecked all connection and sensor position - all good
i guess i will take her to the dealer tomorrow
Old Jan 1, 2010 | 11:59 AM
MR Dan's Avatar
It's your steering angle sensor that needs to be re-calibrated by the dealer. It happened to me
Old Jan 4, 2010 | 06:31 AM
Yousef's Avatar
took her to the dealer they cleared the codes and re-calibrated the sensor....boov they came back again...
they replaced the sensor and all good
Old Jan 5, 2010 | 02:50 AM
tephra's Avatar
yeah it needs to recalibrate the steering wheel angle sensor...
you probably broke the sensor when removing it?? i remember seeing something in the manual about that...
Haitham
Jun 11, 2017 03:34 PM
KiDMaTiX
Jun 5, 2016 04:40 PM
alex3dworld
Evo X How Tos / Installations
84
Apr 21, 2016 08:36 PM
evillancer06
Mar 1, 2016 06:59 PM
nala
Jun 11, 2009 06:22 AM
