Sponsored by:
Sponsored by: CARiD
Fast Key functionality question after remote start install
Old Jan 17, 2010 | 01:37 PM
92gsxbaltimore's Avatar
My wife has a 08 Outlander with the fast key, and I wanted to check to see if it is in fact malfunctioning after the unsuccessful install by Best Buy. The told me that the system would not work properly, and I had them remove everything and returned the system. I already read the manual, and it does not describe this funcitonality, but from what I remember: If you start the vehicle with the Fast Key and then exit the vehicle with the FOB in your pocket, the dash will show an alert that says something like "Verify Key Location". While this alert is being shown because the FOB is outside of the vehicle, and the car is running, it should not be possible to put the car in gear, correct? I remember it working like this before, but now you can simply put the car in gear and drive away without the FOB being in the car. Can someone else please confirm this functionality with their EVO X fast key please. Thanks for your help.
Old Jan 17, 2010 | 01:48 PM
mrMTB's Avatar
With the fast key system, it only affects unlocking the doors or operating the ignition. After the car is running, you can put it in gear and drive normally without the fob in the vehicle.
Old Jan 17, 2010 | 01:57 PM
can I get a second on that please?
Old Jan 17, 2010 | 02:06 PM
cool_g_83's Avatar
^ this
Old Jan 17, 2010 | 02:23 PM
evoch3n's Avatar
You can drive off without the FOB in the vehicle. Tested couple times before, so long as you can turn the car on, you can drive off lol
Old Jan 17, 2010 | 02:25 PM
hotdog's Avatar
It'd have to be that way. If it suddenly turned off or something if it loses contact with the key, what happens when the Fast Key battery dies mid-trip? Just cut power and go "lol"?
They figure if the battery dies, you can always pull out the metal physical key and start it next time.
Old Jan 17, 2010 | 02:33 PM
crimson49er's Avatar
my old '08 lancer GTS & my new '10 mr wont allow you to shift out of park without the key fob in the car... moot point on a manual though
Old Jan 17, 2010 | 10:26 PM
mrMTB's Avatar
Are you sure about that? Not wanting to pull out rulers or anything, but I do believe if I went down to the local Mitsu dealership, their '10 MRs would behave exactly as I've described. Do remember that there's an interlock between the gear change lever and the brake pedal...
Old Jan 18, 2010 | 01:14 PM
yes, i know how to shift my car out of park donkey. if i start my car and get out with the fast key, the tranny wont let you shift out of park until it picks up the key again. i havent tried to shift it out of park with the actual key & no key fob though
Old Jan 18, 2010 | 05:09 PM
MikeAce's Avatar
I have an auto start on my gsr and it works right. If some one tries to take of with it as soon the brake pedal is pressed it will shut off and dissable the ignition and the alarm will go crazy.
Old Jan 18, 2010 | 06:18 PM
Frankiago's Avatar
That's not his question.
My 2008 GSR will allow you to drive off in the car and go as far as the gas tank will let you without the key. It will alarm saying verify location but it won't do anything besides that, and if you fill the gas tank without turning the car off, you can theoretically drive the car for months straight without the key
Old Jan 19, 2010 | 12:52 AM
Optiblue's Avatar
My 08 MR... once the car is started up, even without the fob you can move it out of park!
Ancyker
22
Apr 4, 2016 04:58 PM
Nathan0490
Lancer Troubleshooting
20
Apr 10, 2015 09:35 PM
tsitalon1
Feb 15, 2011 09:47 AM
macPSU
Feb 10, 2009 09:28 PM
beetle_orange
Jul 17, 2008 04:49 AM
