Sponsored by:
Sponsored by: CARiD
Notchy shifter or grinding...is this normal?
Old Feb 2, 2010 | 03:21 PM
tsi1991awd's Avatar
First off, grinding when going into reverse...took the car into the dealer to be looked at and they said this is normal for Mitsubishi's. The thing was, I was not at a 100% complete stop and it will grind going into reverse even though the clutch is disengaged. This did not happen on any of my other 5 speed cars. Camaro, MR2, 240sx, Mustang, Accord...but with this if I am barely going forward and try to put it into reverse, it will grind. Does this happen with anyone else?
Also to go hand in hand with the transmission subject, when I shift, it is notchy. It doesnt take a lot of force to get into gear but it isnt very smooth. When going into 5th gear, sometimes it will go fine and sometimes it will be sketchy. I dont know if its normal to be notchy or not...anyone have experience with this?
The tranny fluid was changed at the dealership. It was overdue, so I had them change so if anything is wrong with the tranny, they will have to fix it seeing as maintanence was done. The clutch and flywheel are stock.
Old Feb 2, 2010 | 03:24 PM
Brembo350z's Avatar
From what I understand the reverse gear has no syncho's, so you'd need to be at a complete stop in order to shift into reverse without it grinding.
Xtremist's Avatar
Yeap, this is common place for the X... Every Mitsubishi I've owned/driven except my TSi have notchy transmissions. They also seem to be prone to colder weather as well, have a syncro smashing good time my friend!!!
Old Feb 2, 2010 | 03:25 PM
Xtremist's Avatar
There's no dedicated reverse gear, the transmission actually uses 1st and 3rd gear to reverse. There's plenty of topics on this if you search.
Old Feb 2, 2010 | 03:35 PM
tsi1991awd's Avatar
My 1g TSi AWD did not grind...never had any other car do it either. Not until this car, but good to know that it is common and supposed to do it.
What about being notchy? I put in shifter bushings and skate bearings for my Talon and it made the shifts really firm, but not notchy like this. And my 5th gear is kind of sketchy like I said...doesnt grind but sometimes it will go into gear fine and sometimes it wont go in so I have to try again and then it will go.
Old Feb 2, 2010 | 05:15 PM
toshibakoludo's Avatar
That's the way it is. Mine does the same if I don't shift with authority. You gotta experiment and figure it out. In cold weather it's is way more noticeable but it gets better once warm.
Old Feb 2, 2010 | 05:34 PM
poof101's Avatar
Just wait till it gets nice and cold and u start her up in the morning...common but normal
Old Feb 2, 2010 | 06:11 PM
charon2123's Avatar
I've found rowing through the gears while I am parked seems to really help out in the cold weather, maybe you can try that; otherwise, pretty notchy.
<----- I have a 2010 GSR, just haven't updated the sig.
Old Feb 2, 2010 | 06:39 PM
Ltdanish07's Avatar
yeah they are notchy SOBs. Once mine is warm enough though it goes away. im at 22k and its still notchy.
Old Feb 2, 2010 | 07:34 PM
macPSU's Avatar
As others have said, yes this is common. The "official" notchy transmission thread is here: https://www.evolutionm.net/forums/ev...on-thread.html
Please divert subsequent discussion there.
z32cctx
Feb 27, 2014 12:02 PM
Luisito Chavez
Aug 16, 2013 10:22 AM
AFD
Dec 8, 2011 12:37 PM
Yamasaki
Jan 3, 2011 10:47 AM
vietdragontekx
18
May 3, 2010 11:02 AM
