Sponsored by:
Sponsored by: CARiD
Weird sound? Help
Old May 18, 2010 | 07:26 PM
RedEvoxGSR's Avatar
Weird sound? Help
ok im getting a clunking sound from my driver side front coilover everytime i have the car n neutral and goin to a stop or going over a bump.. i have done everything i know to try to fix it.. any suggestions??
Old May 18, 2010 | 08:06 PM
xtmx's Avatar
maybe the top nut under the adjustment dial? On mine its a 17mm...
Old May 18, 2010 | 08:33 PM
lousEVOxmr's Avatar
i have the same problem ...
try this jack the car up and after go for a drive no more clunck???
did you change the springs ??
Old May 19, 2010 | 06:41 AM
RedEvoxGSR's Avatar
jack the car up and go for a spin?? no i didnt change out the springs on the coilovers! i have tighten and wd40 the top nut on the coilover under the hood already! now i try tighten the nut that the whole coilover is turning so i cant tighten that anymore!! only when im n neutral!!
Old May 19, 2010 | 08:15 AM
acm_evo's Avatar
You sure the sound is coming from the coil-over? I had a clunking sound coming from the front suspension, and could have sworn it was strut-related. As it turned out, it was caused by the front strut tower brace not being tight enough at the center bracket. I cranked the two bolts down, and the noise disappeared. You may want to make sure the two bolts holding the brace at the center bracket are really tight.
Old May 19, 2010 | 10:13 AM
lancerarmstrong's Avatar
my guess is you didn't perform the pre-tensioning of your coilover springs. before you put your coilovers on you are supposed to adjust the top nut that compresses the spring. It's supposed to be about 1.5CM compressed after it just touches the spring itself. Otherwise when you "max out positively" the coilover spring rattles around because nothing is compressing it. If it "maxes out positively" and the pretension is done, the max it will go is to the 1.5CM compression and it won't rattle around.
Old May 19, 2010 | 10:20 AM
TruSlide's Avatar
chances are, somewhere along the line, you didn't tighten one of the bolts tight enough. you have to go back and walk yourself through the entire breakdown and reassembly. you dont have to take everything apart, just do a once over checking everything. I mean, if it's only when coming to a stop or neutral it might even be the lugs on the wheels. The transfer of motion could cause the clunking during movement and stopping and not during driving. I'd check your wheel lugs first since you obviously have to before getting to the coilover.
Old May 19, 2010 | 10:30 AM
RedEvoxGSR's Avatar
so shld the springs be tight or loose?? i mean when i check my coilovers shld i be able to move the spring around wid my hand or no?
Old May 21, 2010 | 11:18 AM
RedEvoxGSR's Avatar
now all of a sudden the noise has gone away!
Old May 21, 2010 | 11:36 AM
kwlevo's Avatar
check your:
sway bar
top hats
strut bots
wheel bearings
just because the noise has gone away it doesn't mean the problem isn't there.
z32cctx
31
Nov 3, 2012 02:46 PM
Chinkypanda
Lancer Troubleshooting
Aug 20, 2012 09:14 AM
GTE28
Evo X How Tos / Installations
40
Sep 28, 2010 02:31 PM
VajEvo
Oct 1, 2008 01:25 PM
ricanevo
Jul 14, 2008 08:48 AM
