Sponsored by:
Sponsored by: CARiD
is it safe to run fp black on stock block evo x gsr?
Old Feb 10, 2011 | 08:33 AM
mikane24's Avatar
hi i have 2008 full boltons evo x gsr is it safe run fp black? anyone did it already?
Old Feb 10, 2011 | 08:35 AM
apagan01's Avatar
never seen any reason to run a black, unless you are dragging the car or want crazu up top power,,, Red all day long il take it for the spool low mid and top en power and fast spool
Old Feb 10, 2011 | 04:35 PM
homwerk's Avatar
Is it safe? Sure, depending on how much boost, timing and fuel you try to throw at it.
Like Apagan01 said, make sure the FP Black is the best turbo for your application. Are you planning on building your block at a later date? Are you always going to stay on pump gas? These are some the questions that probably need answers before you decide on a turbo.
On a side note, I am not sure I 100% agree with Apagan01 about the spool differences. From the charts I have seen the spool between the FP Red and the FP Black on the Evo X are negligible. I could be wrong on that so don't go quoting me on it . Also, I couldn't tell you about real-world transient response between the two turbos.
For what it's worth, I am also planning on going with an FP Black with mostly bolt-ons. I do have plans to build my block at a later date and will run conservative timing and boost in the meantime though.
Old Feb 10, 2011 | 05:52 PM
murlo26's Avatar
Safe? It can be if you get it tuned correctly.
I think most people look at 8/9's when they assume the black is just a top end turbo...mine barely spools later than my red...see graph.
However, as Homwerk said, if you are staying on pump gas, go the FPred or even green or a bbx/lite turbo...much better pump gas turbos imo.
The transient of the two turbos is slightly noticeable and you do need to rev higher to stay in boost, so I would agree a black is a better turbo for a built block.
Old Feb 26, 2011 | 10:18 PM
ClaudioEvoX's Avatar
and what's better fp black or gt3076 or maybe gt35r???
im thinking on of those.... but here everybody mentions the black, red or green and not the others??
im planning to rum stock bottom in the mean while but later go with better piston and rods...
Old Feb 26, 2011 | 10:35 PM
KJ82's Avatar
FPBlack is definitely a great stock frame turbo if not the best. It's indeed safe to use it on a stock block(with a proper tune of course), and in the long run you can build your motor and then use it to its max potential.
Old Feb 27, 2011 | 10:25 AM
ToFastforU_99's Avatar
I decided to go FP black on my stock block with pump gas and meth injection. I did the normal fuel upgrades walbro 255 and FIC 1100's. my car goes in on March 18th to get tuned by AMS. I am undecided if I want a E85 tune yet or not.
Old Feb 28, 2011 | 02:31 PM
wwEVOsss's Avatar
How does the spool compare between the black and a 3076r?
Old Mar 1, 2011 | 08:30 AM
spdracerut's Avatar
Stock bottom end is..... risky. 500whp seems to be the general limit. If the car will constantly be at that HP target, new pistons and rods would be a very good investment.
Old Mar 1, 2011 | 08:46 AM
escodotcarter's Avatar
From what i have read its not the HP but the TQ that kills the stock block. General consesus shows that 400 TQ is pretty much the limit on a stock block safely/reliably, but im talking about 8/9's. not to sure about X's.
Old Mar 1, 2011 | 02:07 PM
jellyevo's Avatar
If you reach these parts like new pistons and rods, it would be a very high investment, too. labor...
Old Mar 1, 2011 | 02:38 PM
spdracerut's Avatar
Well, couple ways to look at it.
1. Do the labor yourself.
2. It's cheaper than the labor and cost of replacing an entire short or long block after a stock rod makes a nice hole in the block.
JohnBradley
May 31, 2017 11:39 PM
FathouseFab
Evo X Dyno Results
28
Feb 15, 2014 02:04 PM
iBlue
Sep 5, 2013 07:01 PM
majik162189
94
Jan 25, 2013 10:25 AM
dipsetinallday
54
Oct 16, 2009 07:47 AM
