Sponsored by:
Sponsored by: CARiD
Evo X MPG
Old Apr 28, 2011 | 09:29 AM
highlyevolved's Avatar
Originally Posted by jrz
Not complaining, mileage is not why I bought the EVO. Gas could go to $10 and I would still never consider a Prius or some electric POS. Just comparing a 4cyl 290hp with a turbo to a V8 500hp NA engine.
Understood. You are also comparing AWD vs. RWD, which has a lot to do with it. The most fuel efficient non-hybrid AWD car in the country right now is probably the Subaru Impreza, which gets 20 city / 27 highway mpg, which is STILL worse highway mileage then a 500hp Corvette. Now factor in you are driving a performance oriented turbocharged awd car optimized for speed instead of mileage ...
Old Apr 28, 2011 | 09:32 AM
boostless's Avatar
Short gearing is the achilles heel of our cars when it comes to mpg. We cruise VERY high in the RPM band compared to other cars (zo6). Also, the fact that NA engines don't have to go pig rich under boost. It's a gift and a curse my friend.
Old Apr 28, 2011 | 11:04 AM
tsitalon1's Avatar
In town 20-21mpg, on highway 24-26 @65-70mph. 80mph drops to 23.
I use the 42º timing in my cruise timing cells.
Old Apr 28, 2011 | 11:42 AM
CosmosMpower's Avatar
What RPM is the GSR at in 5th at 80 mph? What about the MR in 6th at 80? My S2000 was at 4,200 at 80 MPH in 6th.
Old Apr 28, 2011 | 12:33 PM
Kracka's Avatar
3k RPM is about 62 MPH and 4k RPM is about 85 MPH.
Old Apr 28, 2011 | 07:43 PM
Mini Countryman 4all (AWD) gets 35 highway MPG 28 city, 31 combined
Old Apr 28, 2011 | 07:45 PM
So 80 mph is probably 3,800 in the 5spd. Does that mean the MR 6spd at 80 might be as low as 3,400 etc?
Old Apr 28, 2011 | 08:43 PM
dcgsr's Avatar
You get what you should have expected to get..
Not sure about the accuracy of each readout, but the EVO shows about 26 to 27 MPG at 52 MPH (on cruise) at 2200rpm, and the same stretch shows 30 to 31 on a 08 Z06 but only 1100 RPM. The Evo only has about 1K miles will this possibly increase later?
I just googled for these mpg numbers:
2008 Corvette,
mpg 16/26,
you're seeing 30.5
(17% above published specs)
2010 EVO X
mpg 17/23,
you're seeing 26.5
(15% above published specs)
So both cars are giving similar results on the same surface relative to their published specs....
And FWIW - my highway average is 24mpg, so you're beating me!
Old Apr 29, 2011 | 12:01 AM
The AWD version gets 31 highway, 25 city, and 28 combined but still, it's better. By comparison the Audi A3 gets 21 city and 30 highway, and actually the Subaru Legacy gets 31 highway 23 city. The new 2012 Subaru Impreza actually returns 36 highway, should be the best of the best for AWD fuel economy.
Anyway, the point stands that these are all fine vehicles to get for fuel economy considerations - it is in fact one of their main selling points - but the Evo is not.
Old Apr 29, 2011 | 12:02 AM
Sounds about right.
Old Apr 29, 2011 | 05:34 AM
vGR09's Avatar
damn evo mpg is about same the sti. I get about 19.8mpg...bad
Old Apr 29, 2011 | 07:12 AM
jrz's Avatar
jrz
I understand the lower AWD MPG, I will try to compare the EVO to a AWD 10cyl
Lambo. Now, how much for a used Gallardo?
Old Apr 29, 2011 | 07:25 AM
jrz's Avatar
jrz
2008 Corvette,
mpg 16/26,
you're seeing 30.5
2010 EVO X
mpg 17/23,
you're seeing 26.5
If I am seeing above published specs for mileage, how could I be using up so many tires? This is a stretch of consistant, flat, frequently patrolled, 45 MPH road for testing purposes only.
Old Apr 29, 2011 | 07:44 AM
Under 100K now for a used Gallardo. Some rich guys that can pay cash for a new Evo MR touring loaded might be able to swing one
Old Apr 29, 2011 | 09:22 AM
stubs179's Avatar
I'm getting the same with a stock car, just a cosworth filter and cat-back.
