Sponsored by:
Sponsored by: CARiD
Burned ECU
Old Oct 12, 2011 | 04:06 AM
mikoboi's Avatar
Burned ECU
I have a problem on my ECU. I did some research what causing this problem. Saw this link on the codes for the ECU found out it was #93 on the list which is "ECM GROUND" check this ----> http://www.techturkey.com/forum/ecu-...cu-pinout.html about the code o
This is the 2nd time the box and pin burned .. Same pin was burned on the 1st ECU and this time it did it again. Any inputs/ suggestions?
Old Aug 20, 2013 | 06:07 PM
Martg84's Avatar
Have you ever received any troubleshooting tips on this, I just found mine burnt as well.. pin 81 to which is ECM ground too
Also .. how did you fix it ?
evoscan
52
Jun 20, 2017 01:46 AM
Lion_Sam
May 5, 2015 05:49 AM
3VOLUTIONIST
Mar 23, 2015 08:29 PM
djd24
Dec 3, 2008 08:52 AM
antics22
Evo X How Tos / Installations
Apr 3, 2008 11:02 AM
