Sponsored by:
Sponsored by: CARiD
Evo X MR at AutoX? Some questions... :)
Old Nov 4, 2011 | 05:13 AM
Iowa999's Avatar
Originally Posted by justin81
Just my opinion but I would run off/off in SST mode and left foot brake. That's the beauty of the SST is you can left foot brake an it will stay in redline the whole time.
What does turning off the help for the AYC (which is what happens when you go from plain-off to off-off) have to do with left-foot braking? Isn't one of the best wheels to apply the brakes to at corner-entry the inside rear? Why would you turn off something that only applies the brakes to the inside rear, especially after you have turned off something that applies the brakes to inside front?
Old Nov 4, 2011 | 12:15 PM
justin81's Avatar
Anytime you start to slip the car will apply the bakes and you will start to loose speed. Oversteer is your friend a lot of the times and you want to be able to rotate the car as much as possible when needed. The best way to do this is in off/off. You can then use left foot braking and throttle steering to manage the oversteer.
Old Nov 7, 2011 | 02:10 PM
Iowa999's Avatar
Let me see if I have this straight. I want ASC in off/off so that the car doesn't apply the brakes to the inside rear wheel because brakes slow you down, but I do want to left-foot brake and, therefore, apply the brakes to all four wheels, including the outside front, partly because oversteer is good ... is that about right? If so, then that's fascinating.
TruSlide
13
May 23, 2023 07:20 AM
tephra
44
May 17, 2021 03:38 AM
KiDMaTiX
Jun 5, 2016 04:40 PM
europaul
Mar 16, 2016 10:12 AM
Illest92til
Sep 17, 2015 06:00 AM
