Sponsored by:
Sponsored by: CARiD
Problem with Front Parking lights and DRL
Old Mar 26, 2012 | 11:05 AM
desiromeo812's Avatar
Hello All,
Picked up a used Evo X yesterday, noticed my front marker lights and DRL's do not light up. With the headlight switch to the parking light position all the rear lights work but no lights in the front. Can someone point me to the right direction of what the cause might be?
Checked with the past owner and he said he never modified any lighting in any way.
SSS Hid's and fogs work flawless.
All help is appreciated
Old Mar 26, 2012 | 11:08 AM
yoshe200's Avatar
I would check the relays and see if they have gone bad or not. (and the bulbs but I doubt all of them have gone bad at the same time...)
Old Mar 26, 2012 | 11:09 AM
ithveno339jfkj4kjekjqqqq's Avatar
parking lights should come on, but i think the DRLs don't until you put the e-brake down...
Old Mar 26, 2012 | 11:10 AM
yoshe200's Avatar
(relay diagram is on the back of your fuse box cover)
and congrats on your Evo purchase!
Old Mar 26, 2012 | 11:38 AM
I have tried swapping relays around and it made no difference. E brake was down during the relay swap testing. I am not too concerned about the DRL's but would like my marker lights to switch on. Anybody able to tell me what fuses and Relay's would be directly causing this?
And thank you on the congrats, I just sold my Evo 9 and so far other then acceleration the X has impressed me. But I'm sure that will change when I throw some E85 and bolt ons.
Old Mar 26, 2012 | 11:40 AM
Kracka's Avatar
If it's still under warranty let the dealership worry about it.
Old Mar 26, 2012 | 11:58 AM
Kracka I Pm'd you a week ago, I love the path you followed on mods on your X and would like to get your insight on a few things.
Its only got powertrain so no bumper to bumper coverage.
Old Mar 26, 2012 | 12:01 PM
Kracka's Avatar
I must have missed it...let me go check my PM's.
Old Mar 26, 2012 | 12:17 PM
I'll send you another
Old Jun 28, 2012 | 06:05 PM
nastorino's Avatar
what ended up being the problem?
Old Jun 16, 2014 | 09:27 PM
honki24's Avatar
I have the exact same problem. What was the solution? I found the DRL fuse was missing and replaced that which fixed my DRLs but not my parking lights...
Old Jun 17, 2014 | 08:50 AM
Veronica's Avatar
Check the bulbs. Start with obvious stuff first...
You do not know if the PO had the bulbs burn out and never noticed...
Old Jun 20, 2014 | 11:50 AM
Mani8448's Avatar
Just replaced DRLs on my 2012MR.
My engine had to be running and the E-Brake had to be down (released) before the DRL's would come on.
Not sure if both those conditions also apply to the parking lights or not.
Old Jun 20, 2014 | 08:39 PM
liljordan46's Avatar
hey guys Im new here , I have a problem with my evo 8 , my right side front head light is not going on , I changed the ballast and it worked for about a week and now is not working any more , do you know what might be the problem?
Old Jul 5, 2015 | 03:51 PM
w8less1der's Avatar
Bringing this back from the dead, hopefully with some new information.
I read about quite a few people complaining the lights keep going out, but after what I just went through I am wondering if it is faulty wiring causing the issues. I just replaced one of the DRLs today and the DLR still did not light up. I took out my multimeter to perform some testing and it appears the blue wire is not connected securely to the silver circle that the bulb fits in. Check out the picture I attached and let me know what you think. Is it possible that all we need to do is solder the raw wire to the silver circle to eliminate the DLR bulb issues? I hope I am not oversimplifying this, but if I am let me know.
Attached Thumbnails Problem with Front Parking lights and DRL-lancerralliartdrlsocket.jpg
eddielmc
16
Jun 7, 2019 05:56 AM
europaul
Mar 16, 2016 10:54 PM
hispanicpanic
Aug 19, 2015 06:03 AM
jayt27
Aug 14, 2015 06:08 AM
overdrive1
Canadian Forum
Jan 4, 2012 10:52 AM
