Sponsored by:
Sponsored by: CARiD
car sputtering, running lean, unable to boost
Old Jul 5, 2012 | 09:03 PM
Pbayr0lla321's Avatar
Originally Posted by mct9891
Solution : seems that after 7300 miles the filter off the fuel pump clogged up. My shop did a pressure test and i was only getting 10lbs of pressure! Filter was replaced and the car's good as new.
Amen! Glad it was an easy fix
Old Jul 6, 2012 | 10:50 AM
germanevo8's Avatar
Thanks for posting
Old Jul 6, 2012 | 02:24 PM
dldjros69's Avatar
how did it get clogged?
Old Jul 7, 2012 | 10:44 AM
mct9891's Avatar
No idea
Update: very weird, but it's doing it again. Not sure if the DW fuel pump was burned out because of it, but now it's probably even worse than before. Stalling, and a lean idle.
Gonna see if putting the stock pump in helps...
Old Jul 9, 2012 | 12:41 PM
AaRoN_D_EvO_X's Avatar
Autozone will read your code for free. Wild guess that it might be the P1235
Old Jul 12, 2012 | 10:14 AM
mct9891's Avatar
Ok, Final Solution (hopefully) : for the short amount of time that the pump had no fuel strainer it must've picked up some nasty dirty gas and clogged the actual fuel line because I wasn't getting any fuel to the motor at all...
So I blew compressed air through the lines and out shot a decent amount of gas and some debris.
Moral of the story, never ever run without a Fuel pump strainer/filter/sock whatever the hell u want to call it.
Thanks for the help guys.
papabeardoe
Jun 13, 2017 04:06 AM
pistons4550
Mar 16, 2016 10:53 PM
Miller_x
Jan 9, 2013 05:29 AM
Inprogress
Sep 20, 2012 09:15 AM
quadrophine
28
Mar 7, 2012 07:36 PM
